Car sputtering and running RICH on 2 cylinders
Well one of my colant hoses blew off on the dyno so i sent my car to my buddies shop to bleed the system since i dont have the snap-on tool... He also changed my MAF sensor that he said went bad (and was codeing)
let the garage, car was running great for about 1-2 hour then it starting running rough at idle and studdering a little while excelerating...
At adle the right rear tail pipe is smoking black,,, and if I give a little gas it gets even worst...
I have no codes so dont really know where to start looking
Car has k24 turbos, fabspeed exhaust, Evoms intake and a 5bar... with a Unitronic tune 1.1 bar
What i dont get it why is it only one exhaust (3cylinders) running crazy rich??? fauled plus, jammed open injector??
Any idea?
thanks
Any idea?
thanks
well if it was before you made any changes( maf) then maybe its the parts he put on...
did you just put on a lit or something else and tried to dyno?
No offense but who/what is unitronic? I seen issues with some unknown tuning programs as well...
2001 996TT 3.6L and stock ECU
Well not sure it's the tune since it running on many of my friends with no issues.... Is it possible that a vacume came off??? What's a lit? What I don't understand is why is only one exhaust side running rich, and not both!
here is one we received after a client had CEL and other issues...
with stock k24 and 1,1 bar you dont need a 5bar fpr.. ..at this point try at first a stock 3,8bar fpr and stock file...maybe before you do that you should analyse with durametric the valvetronic regulation , lambda value.....
with remote flash one of the good 911tuner can give you a stock file...
So you guys really think its a computer related problem? I just find it mysterious that it was running fine for a while then outta know where this problem!
I would look at the last upgrade you did and verify everything is ok with it and also check on Durametric to verify fuel trim, Lambda readings and other things to confirm everything is working properly.
thanks
thanks
Last week my car was sputtering BADLY, and when I say badly I mean it was like it wanted to stop....huge misfires and backfires....this was happening at around 3k rpm on mid throttle-mid boost.....
Well....the damn MAF was the issue...Dave at EPL suggested me to try and drive with the MAF unplugged. It ran much better. I threw in a new MAF (I had a 986 MAF laying around) and now it runs silky smooth.....
The funny thing is it didn't throw ANY codes before....no lights on the dashboard...nothing...but the MAF was faulty nevertheless.
mark
It was scary...I could hear turbos spooling up and down with the engine sputtering and spitting fire....what a horrible feeling...
Being sure that there are no air leaks it's very important though....as you can go look somewhere else like in my case...
PorscheEnthusiast
11-13-2015 02:23 PM
