loss of power
loss of power
I submitted a thread several weeks ago about loss of power on boost and really appreciate the responses. It appears it is not a boost leak problem as there appear to be no leaks and boost gauge shows 1.0 bar(car is stock with the exception of EPl flash). The car has about 5,500 miles and the problem started about 300 miles after I had the flash done. When getting on power the car stutters and feels real flat above 3,500 - 4,000 rpm. It is now at the shop and we have replaced the plugs and the coil packs and have installed new audi diverter valves. Also no code has shown up. Disconnecting the wire to the MAF also made no difference.Thanks in advance for any suggestions.
many failures are possible.
boost leak test at first....
if plugs, coils okay, no boost leak, then check fpr regulator and the hose on top, check fuel pressure...fuel pump,
after that you need durametric, check valves for valvetronic etc...datalog...afr left right,maf sensor!!
Please clarify one point. You say the car is in the shop at the moment and you have changed the plugs and coils. Be more specific. Did you change the plugs and coil packs before you took the car to the shop or whilst the car is in the shop.
Can you see where I'm coming from on this. If you have only just changed them whilst in the shop have you been out in the car yet and know for sure the problem is still there.
If you are still experiencing the same problem after all that, i would be checking your fuel pressure and delivery. Have you checked the fuel pump U pipe in the tank, its know to fail on just about every 996tt......its just a matter of time.
Spoke to your shop this morning...
The car did arrive to them with:
Fault Number:P1504
Description:Porsche fault code 410 - DVE fault: necessary intake air
They need to pressure test (asked them to do this last week) and check the n249 control system (dv related).
This should be a very simple fix once they identify the issue!
Fault Number:P1504
Fault Number:P1504
Fault Number:P1504
I dont know where your geting your fault code information from but here is the POSES fault code information:
DME 7.8
2442 P1504
0-174
page 1
DME 7.8
p1504
Printed in Germany, 2000
P1504
410 Throttle jacking unit, emergency air position - signal
implausible
implausible
Diagnosis conditions
Ignition on (approx. 30 sec.)
Possible fault cause
No adaptation performed
Throttle part
Affected terminals
The fault is entered during the adaptation phase.
Diagnosis/troubleshooting
Note!
Work instruction Display OK If not OK
1 Perform adaptation
♦ Switch on the ignition
Wait one minute
Do not press the accelerator
Switch off the ignition for at
least 10 seconds
least 10 seconds
Read out the fault memory
Fault entered
Fault entered
Step 2
End
2 Replace throttle part ⇒ Step 3
3 Perform adaptation ♦ Switch on the ignition
Wait one minute
Actuate accelerator pedal
least 10 seconds
least 10 seconds
COBB Tuning
03-29-2016 09:26 PM
COBB Tuning
09-09-2015 09:13 PM
Ferrari
08-24-2015 04:35 PM
