PSM / ABS failure drive to workshop...
#32
wow, how long ago did i need that info?! lol. wish my treads lasted as long as these threads. that was back when i had 225/40 fronts against 315/30's rear, i think? i'm now properly fitted at 235/40 x 315/30 and only got squirelly once today at 5000+ feet. i'm blaming altitude
#33
Right when I stopped in front of the house, the error came back?!? When it happens I get a really rough idle and it sounds like it wants to die right before it revs back up. No CEL though?! I wonder if it stored any codes? I may have to find someone to get the codes read. I'm afraid it will be eternal guess work otherwise.
#34
we shouldve at least read it out dont you have an obd reader?. but i got a cel too ( my tb needs cleaning ) at the bottom of the hill, which was like 25 mi down. un fkn believable that mountain sheesh. what like 50 miles up and 50 down!? i swear, i couldve ended up in palm desert at the END of a 3day wkend.. we put some miles on.. next time. beach/canyons and i'm buyin.
i think your maf is toast
add: altitude. that'll cause a cel. lol
#35
I'm thinking MAF as well. Why would PSM/ABS cause a rough idle; wouldn't make any sense?!
That road is long for sure! I'm actually tired from driving LOL I'll have to dig up my pics and post them up.
#36
Did you just have PSM issues or did you get the "PSM/ABS failure drive to workshop message" ? I still set off my PSM on occasion but it's just my crappy stock suspension that triggers it; I just turn it off now when I'm out for a spirited run. Need to get some coilovers though; the handling is too spooky when you start pushing it.
#37
get the actron 9550 or the next model up on ebay. perfect for guys like us that can;t do sh*t about what the code is anyway.. but it does help to know thr number and also helps with resetting readiness codes etc. i'd say get a durametric.. but it's more than i can use/need.
75 bucks on ebay. actron yellow/orange chinese ( red?! ) obd scanner/reader. you'll know it's from china as the label says on it "contains lead, wash hand if you touch" ) i'm not making this sh*t up.
#38
Yea, that's what I meant. PSM failing wouldn't cause a rough idle but a failing MAF causing the PSM error could make sense. If it can't read the air intake/throttle correctly, PSM probably wouldn't know when to intervene. I'm betting my money on the MAF. Will read codes first though.
#39
but i'm just now old enough now to think i want the car without any of the nannie helpers or drivers assist. my govt is enough
#40
add: youve gotta grab a obd reader for 75 bucks lol
#41
Craziest thing happened to me after I took apart the whole back end of the car to replace my spark plugs. I did my 30k mile service and went to open her up on the freeway on ramp and then my driver side upper boost hose popped off. I could really hear my turbos, but had no power and then my PSM and ABS lights came on. I then limped home and took a look. Sure enough the boost hose wasn't seated well enough when I put the retaining clip on. I remedied the problem and cranked her up.. no lights and she runs like a champ now! )
#42
#44
underlying issues, be damned
