wheel spotting
wheel spotting
just used a name brand tire and wheel cleaner and it spotted my rims, used a small amount of laqure thinner nothing wax cleaner still spottie but nit as bad any ideas , they look like water spots .. thanks
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
Do the wheels have a clear coat? If it ate the clear, you're hosed. You can try a polish like mothers and use a high speed buff to see if it helps. If it does not, you can look into sanding. However, if you're not experienced with sanding or polishing alloys, I would have a professional shop take care of it. Generally doesn't run more than $100 for a whole wheel.
Originally Posted by dhalen
You could start with some punctuation. ![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
Steve, I used some name brand cleaner that left huge spots on my Fikse lips -had to repolish each section as nothing else would take it off. What type of finish is on your wheels (painted, clear coat, polished?)
FYI... https://www.6speedonline.com/forums/...y-returns.html
FYI steve never used punctuation even years before his stroke....it's just the way he rolls
Lowtush
01-25-2022 10:48 AM
Tremelune
08-23-2015 01:17 PM
