Turbo Trans Mount _ Help diy
I noticed a lot of posts on the dreaded trans mount and replacing it with the stock part 997-375-033-03-M100 or aftermkt solid or even using window weld. But I would appreciate a diy on changing the mount.
Question: Anything I should be aware of or a little tricky? Did you need to support or lower the trans to access the two bolts that attach the tranny mount to the tranny, as I noticed the coolant hoses appear to be in the way of getting these bolts out (by the way are these bolts 16 mm??). thank you, kenny
04-28-2022 12:38 AM
ECS Tuning - VW
08-19-2015 08:58 AM
