Dammit Effing Hell...
#46
Originally posted by PorschePhd
Not really. You would think so but it is more like this. Some never fail, some do. There is only one pattern linked to airfilters and oil. It is almost a QC issue I think
#47
i'm a supra guy (thinking about a 996tt) - why can't you convert to MAP?
i used the Powerhouse Racing MAP-ECU (which should be car-agnostic) and, for the most part, i'm very happy with it. Remove the MAF, plug it into the wire harness, program your fuel, and you're off in less than 3 hours.
Powerhouse also workss on porsches so it might be worth a call to them to see if they've successfully used it on a 996tt. (If it does work, you might experience a nice little hp bump on the top-end since MAFs tend to be fairly restrictive.)
#48
#49
9FF uses pressure sensing in some of their >700hp conversions and replaces MAF (on Motronic).. I know Protomotive does that too on high output 993TTs (I have it), I would guess he does it on 996 too..it should be around a couple thousand dollars to do the conversion.
#50
It can be done, but look at it this way. How many would really be sold at several thousand for the kit? It would take a lot of time and at the end of the day the cost to do it would go through the roof. So any justification is gone. Don't kid yourself it has and can be done.
Motec will not cost you 8K. You can expect that by the time you are done you will have 12-15K in the kit. The wiring harness we have made are 2500 alone! You would also need to run a different ABS brain(GT3cup) and several other issues that need to be converted.
Jean.
The kits I have seen from Todd still use the MAF in the TT. The one that I saw that was in the pressure side was still using the factory MAF and was blowing them as soon as it was coming up on boost. They switched it back out of stream.
Jean.
#51
Stephen
Yes, I was not sure Todd was using MAP on the 996TT (Motronic), since I know he worked with Motec on some projects.
I think your biggest limitation for wild hp in the Motronic kits is still the MAF though, at least this is what the Germans think, it seems like the only way around it is aftermarket EFI.. One of your new Autronic kits should be a good testing bench.
Thanks.
Jean
Thanks.
Jean
#53
hey sharky, have you ever cleaned the maf with electrical contact cleaner. in know it's a different animal but when i installed an evo intake/cone filter, the oil in the con filter fouled the maf. a quick and easy clean of the maf and everything was alright. i am expecting maf on my c2 to get fouled too due to the evo v-flow :O
#55
I read somewhere in this thread that the sensor has a membrane that blows. If true, and since air follows the "square law", then the absolute pressure seen between your intake and your filter is going up exponentially (squared) when you romp on it. I'd take another look at your filter and how restrictive it is with the amount of air you are shoving into that block and especially whenb you jump on it. The manufacturer should be able to provide a differential pressure curve.
I stayed at a Holiday Express last night.
Now, back to drinking.
