Is front camber adjustable without GT3 arms?
I am in the process of upgrading my suspension and so far have the following parts:
Techart coilovers
Front/rear strut plates (not adjustable)
Eibach sway bars
Adjustable drop links front and rear
Adjustable solid thrust bushings
Rear upper arms
Rear toe links
It seems this will tranform the handling and allow me to dial in the alignment. My question though is camber adjustment on the front. How is it adjusted without adjustable camber plates or GT3 arms? Should I still get them for the front and rear?
Colby
Techart coilovers
Eibach sway bars
Rear upper arms
Rear toe links
Colby
It is adjustable through the slots in the strut towers but at most you will get -1.2 or so and that is if you are lowered to GT2 height. The GT3 control arms make it a breeze with the added benefit of increased track. Just make sure you mount the arms in reverse ( left arm on right side snd vice versa) and use the off centre diagonal brace location which will allow you to keep caster in spec.
If you don't do this you will rub on the front fender liners in most cases.....
Techart coilovers
Eibach sway bars
Rear upper arms
Rear toe links
Colby
Techart coilovers
Eibach sway bars
Rear upper arms
Rear toe links
Colby
That should work. I believe the only drawback with the modes is that they raise your ride height in the front by about 1/2 inch, if I'm not mistaken.
04-28-2022 12:38 AM
