Opening with key after 5 days
It's rare -- but a couple of times I've had to open the car door with my key after the car goes to "sleep" after the 5 days. However, it seems that when I do use the key, I always end of triggering the alarm -- which I then turn off with the fob. Am I not opening the door correctly? What's the trick?
you still have to unlock the car after turning the key as the security system is still armed. I also do what rainey said. After you unlock the door you have a little bit of time to hit the unlock button and disable the alarm.
04-28-2022 12:38 AM
