What size is the 996 turbo stock cat inlet size
Old 09-24-2011 | 03:00 AM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
Just wondering what size the cat inlet size is, or k16 turbo outlet diameter, so I can find a high flow cat to match up with it. Will the stock exhaust tips fit over a 2.5" pipe? Thanks for any info.
Old 09-24-2011 | 08:52 AM
Tim941NYC's Avatar
It does not matter. you take what ever cat physically fits then you would cut the inlet off fit a transition fitting say 5x4ish to fit it to the turbo and run what ever the outlet is. You really do not want to neck down out of a turbo in to a cat. the cat is a restriction in itself that's why the cat body is double if not more then the pipe that feeds it. Why not just lose the cats?
Old 09-24-2011 | 10:22 AM
BOOSTTT's Avatar
I have got to be able to pass emissions. I know I do not want to neck down. That's why I'm asking what the turbo outlet size is, so I don't buy a cat that does.
Old 09-24-2011 | 12:54 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
You might consider picking up a used catless system or cat bypass pipes and saving the one you have come emissions time.
Old 09-24-2011 | 02:04 PM
BOOSTTT's Avatar
I don't want a catless exhaust. Man, I hope I don't have to remove this exhaust just to measure it. I was hoping someone would know.
Old 09-24-2011 | 03:30 PM
your going about this all wrong.... there a O ring... then what about the flange.. where are you going to get it... we use 3" OD cats and make it work with our flanges.. like this... simple...
I dont think the stock tip will fit over the 2.5" its 2 and 3/8ths...
heres one without thew cat.. 3" pipe... but the flange in the other side is not 3".... the ID is 3.25".\
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 09-24-2011 | 06:45 PM
BOOSTTT's Avatar
Thanks for the info! I have a friend that has a laser cutter and it's computer guided. I'm not sure how he exactly does it, but he can fab just about anything and does great work. I just need to order some parts and didn't want to remove my exhaust to measure the turbo outlet diameter. He is very slow about getting things done, so I just wanted to get the ball rolling. Thanks for your info. I really appreciate it.
Old 09-25-2011 | 12:03 AM
BOOSTTT's Avatar
Cool! I can just use the factory flange like this guy and I can get those exact same cats too. He was able to fit the tips over the 2.5" exhaust tip as well!!! Too easy!
https://www.6speedonline.com/forums/...urne-fl-2.html
AJUSA.com
997 Vendor Classifieds
10-08-2015 06:50 PM
08-19-2015 07:55 PM
PelicanParts.com
996 Vendor Classifieds
08-18-2015 04:45 PM
PelicanParts.com
996 Turbo Vendor Classifieds
08-18-2015 04:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 04:42 PM
Quick Reply: What size is the 996 turbo stock cat inlet size
