Boost hose came off...I need help putting it back
#46
yup - you still have to use the new style 997 clamp. i squeezed it a bit before reinstalling it.
#TeamAIM
#TeamAIM
#47
i think my problem might have been using the 997 clamp with the old rubber seal...
#48
so I tried to the fit the new metal fitting with the new rubber seal and 997 clamp, but the clamp would not get a tight fit no matter what I did.
I ended up going with the other style clamp (one side up, one side down) and it clicked right in place and was very snug. Did a few runs and no problem...then on a fourth or fifth run at like 1.4ish bars it blows out and I lose another seal and my new metal fitting gets dinged
I need to figure out how to do some wire x clamp to hold in (like the other member said)
#49
2001 996TT 3.6L and stock ECU
#50
This concerns me a bit. Should go in straight with minimal sideloading. Might need to trim the hoses a bit. I've had no issues at similar boost levels with both stock and Forge hoses and fittings.
#51
this problem is super annoying
#TeamAIM
#TeamAIM
#53
996 110 631 74 is the part number for stock left lower hose. sonnen sells it for like 50-60 bucks
#TeamAIM
#TeamAIM
#56
eh i thought about that too. i am assuming the 997 one will fit best, im not sure if the shape is the same tho. let me know how it goes.
#TeamAIM
#TeamAIM
#58
I am going to try a 996 oem hose....if that comes off then my intercooler end take somehow got messed up.
I have tial alpha 28 turbos...not sure if that is different than the stock compressor clock
#59
it's the same, thats why you can use stock hoses
#TeamAIM
#TeamAIM
#60
http://cgi.ebay.com/ebaymotors/Porsc...item5ad38f45e2
they are perfect and did the job .. boosting till 1.75bar and it fine ,,
