Headlight lens restoration
I saw Ecthheads headlights today...OMG...AMAZING!!!! I can't believe they are actually the original units. They look better then mine do on an 09 997!
Even the insides of the lights looked factory fresh.
Incredible!
PS: EH, let me know If I need to buy you some new shocks that was pretty fun!!!
Incredible!
Impressive results! I had a guy here that polished my father's allroad headlight lenses and although it made a huge difference I feel like they are still a bit too cloudy.
He was a little scared to work on the turbo, he tried very gently and to be honest there is no difference.
Maybe I should try and do it on my own...
My headlights were horrible- not sure what the previous owner did or didn't do, but they were ugly. I really disliked looking at the front of my car. I had a headlight guy come to the house last year who went to town with his buffer but did little to help- so I wrote them off.
The guy at the shop last week took out the headlights and got nasty with them. Started with coarse wet sanding and worked up to the fine buffing. As Vid says- they look like new, really incredible. So for anyone thinking theirs are too bad just give this a go. I tried it myself as week, but you really need to remove the lights and spend some time with them.
Good luck!
Fun time yesterday Vid- but yes do have one broken shock and another 1/2shaft coupler so spent the rest of the time in front wheel drive trying to hit the jumps... Couldn't get any traction. (Traxxas Slash 4x4 RC Truck with 11.1 battery=55mph. Vid jumping my truck = triple flip and broken stuff but good time!)
Good luck!
I just redid my headlights too, and I took the headlight washer off (chrome disk.)
Basically once the headlight is out, turn it over and you will find a rubber tube, which is connected to the actuator of that disk. I took my air pump and placed the plastic nozzle that is used to inflate pinch valve items to it. Then I wrapped some electrical tape around the nozzle and the rubber tube to make sure it stays on and then turned the pump on for like 2 seconds. The washer arm extends out a few inches and will stay out as long as there is pressure in that line.
Now to take the disk off, you have to be very careful since it is plastic. It is basically pressure fitted and with a small pair of pliers it can be squeezed off. Hope this helps some.
I used the 3m kit. I didn't take my headlights off however. I masked off the paint and went to town with the drill. Lifted up the silver washer things and held them up with a golf tee. Came out looking like new.
Golf tee... Ingenious. I will have to try this as I don't really feel like taking the headlight out.
Make sure you use at least 3 layers of well placed masking tape.
It only takes 2 minutes to remove the headlight, using only the tool provided in the kit provided with your spare tire.
As an aside, has anyone ever just used toothpaste? I had a few BMW buddies that said toothpaste did wonders for cleaning up headlights. But I'm guessing it would also strip away the UV protectant. I'm going to head to the local autozone and AAP to see if they have the meguiar's restoration kit. The edges of my lights are starting to look like they are clouding up. My guess is from excess wax when waxing the car.
Jon
ECS Tuning - VW
09-24-2015 01:38 PM
ECS Tuning - VW
09-24-2015 12:29 PM
