Headlight lens restoration
Old 10-10-2011, 07:32 AM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Had a little time this weekend, so I did a little restoration on my headlight lens. I had already tried one of those kits you see advertised on TV, but got nowhere.
It was fairly badly pitted (see "Before" photo below). First, I wet-sanded with 600 grit to remove the pits (Photo 2) and then buffed it out with rubbing compound. It took a while - almost 3 hours - but the result was a big improvement.
Old 10-10-2011, 08:32 AM
shtfrbrains's Avatar
shtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud ofshtfrbrains has much to be proud of
Looks great! How did you work around that little chrome disk?
Old 10-10-2011, 08:58 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
Great work, congrats!
Are you putting something over them now, 3m or some film covers?
Old 10-10-2011, 09:00 AM
DNugget991GT3's Avatar
i did the same with mine this weekend as well !
i used the 3m kit which consists of 500 grit, 800 grit, 2000 grit wetsand, and some compound. mine came out great too !
Old 10-10-2011, 09:53 AM
FAST FWD's Avatar
Carefully Seriously, that's all I did.
That's a good idea. Hadn't thought of doing that.
I think that if I had had some 2000 grit, it would have gone a lot faster. The jump from 600 to rubbing compound leaves a lot of scratches that it takes time to get out.
Jon
Old 10-10-2011, 10:27 AM
Etchhead's Avatar
Etchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond reputeEtchhead has a reputation beyond repute
Mine look like they micro cracks or hazing. I had a professional detailed have a crack and it didn't help much. Wonder if this 3M kit you have works any better. Does it have a tool that plugs into your drill as well?
Old 10-10-2011, 02:29 PM
alex55's Avatar
If you are not putting nothing over the headlights they will become worst like the first time because you took a layer of protection when you polished it.
Good luck!
Old 10-10-2011, 02:44 PM
statepkt's Avatar
statepkt is infamous around these parts
^What he said. Originally the headlights had UV protection on them. Now that you have scrubbed those off and are not re-applying something, your headlights will only degrade more quickly.
Now I have only found 1 kit that actually includes UV protection. What are you guys using, just the 3M film covers?
Old 10-10-2011, 05:08 PM
FAST FWD's Avatar
OK! You guys convinced me. I have a set of Lamin-X films inbound.
Thanks!
Jon
Old 10-10-2011, 07:31 PM
tjj7ff's Avatar
tjj7ff is infamous around these parts
I used the Meguiars restoration kit that includes the a bottle of UV protector. It does a pretty good job on medium to light scratches. Heavy scratches will require using a heavy wet grit sandpaper before using their product.
Old 02-17-2012, 11:11 PM
Etchhead's Avatar
Thread revival but tickled pink!
Had my car at a Sportech for some maint and one of the body shop guys in the same complex came by and said he could get them new for $100 or free if no improvement. He ended up removing the lights and wet sanding with coarse grit then finer and finer finishing with a buff. My headlights have always looked horrible but now they look brand new! I'm sooo pleased with this, and to think I was looking at new units on ebay for >$1200.
Now have to figure out what is needed to protect them going forward and sounds like a debate out there.
Old 02-18-2012, 09:49 AM
Turkish's Avatar
Turkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond reputeTurkish has a reputation beyond repute
They look great.
Old 02-18-2012, 10:59 AM
Blockhed's Avatar
Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !Blockhed Is a GOD !
I have to do my front and rears and then get the Film on fronts.
Jon let me know how you like the film and how it looks.
Old 02-18-2012, 01:10 PM
FAST FWD's Avatar
I got the film, but haven't put it on yet. Looks pretty straightforward to install.
I've been traveling a lot. I should get to it when I get back to the US in a couple of weeks.
Jon
Old 02-18-2012, 05:01 PM
No SubstiTTute's Avatar
No SubstiTTute is infamous around these parts
I put a set of Xpel protective headlight film on when I bought a new 2000 Audi S4 back in 1999. I ran up 103k miles over 9 years in all types of road conditions with no problems whatsoever. They looked great when I sold it so I just left the covers on.
Quick Reply: Headlight lens restoration
