Who tuned your A28's? (help me decide)
Old 11-05-2011 | 02:18 AM
FlyingGuy's Avatar
FlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant futureFlyingGuy has a brilliant future
thanx for all the input. all of it, warnings and all.
question tho... since the early torque is what plagues the rods with A28s, how safe are the A30s on stock rods, seeing as how theres a later torque curve?
some of the discussion has actually made me reconsider what i wanna do with this car. if i end up wanting/having to do rods, i may actually make a jump in turbos. thanx for everyones input
  #62
Old 11-05-2011 | 09:47 AM
johnspeed's Avatar
It seems to me that once you add meth to the equation with any of these turbos over stock K24's,,,this Rod/head gasket issue is a consideration to be looked into.....
  #63
Old 11-05-2011 | 09:56 AM
MBailey's Avatar
I would not let a few anecdotal stories spoil your opinion of a fantastic turbo. There are far too many variables that can contribute to bend rods to assume the turbo makes too much torque for the rods. There are hundreds of these setups running just fine all over the world. I have run these in a high timing high boost setup for three years (stock block) as a DD at the TX Mile with no issues. You can find bent rods out there for all turbo setups.
  #64
Old 11-05-2011 | 10:30 AM
johnspeed's Avatar
Originally Posted by Tony@epl
Meth plays no roll in this... In fact it most likely helps prevent damage by suppressing knock.
How can you say that???Meth allows for more boost safely ,thus more power!!As you know this because you use it to make more power,dont you??.....
  #65
Old 11-05-2011 | 10:33 AM
johnspeed's Avatar
The key is a unorthodox boost curve, tapper up.
Example...
1.2@ 3000, 1.25 @ 3500, 1.3@ 4000...... and so on. 1.5-6 is safe if tuned properly at redline. limiting torque down low is the key.
A28's will make 1.5 bar by 3300-3500 rpm is you let them rip!
Different gears make the load different,thus boost comes on differently in different gears....It did with your past tune on my car.......
  #66
Old 11-05-2011 | 11:36 AM
rdss's Avatar
rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !rdss Is a GOD !
Originally Posted by Powell
I never thought I'd even upgrade turbos from K16s... Boy how things change... :(
hilarioushilarious specially you Chris that builded a mounster:eek:
  #67
Old 11-05-2011 | 11:41 AM
johnspeed's Avatar
..I also said when I had my original X-50 that the flash and exhaust was going to be it....lol....But I guess alot of us are never satisfied even though we try to fool ourselves into thinking that......
  #68
Old 11-05-2011 | 03:50 PM
johnspeed's Avatar
John, Ive been telling you this since day one... the dash is far to inaccurate and slow to be your only measure of boost.
Sure cars will spool slightly faster in high gears, but this really isn't much of an issue.
OK,,,,, Then when you are in 2nd gear and floor it at 3,000RPM the boost goes to 1.2 bars...But then when you are in 4th gear and do the exact same the boost goes to 1.4 bars...So,know matter if the dash isnt accurate for exact boost,its still .2 higher..Yes,there is probably rounding in there as you have explained.
Are you saying that that is not that much of a load difference on the motor with .2 extra bars because I would think that the extra .2 would also make more power,thus harder shock on the engine at the lower rpms??
In most cases thats what I have seen a .2 bar difference with tunes and 1 bar wastegates with those same type of test examples....Just trying to understand here....
  #69
Old 11-05-2011 | 04:10 PM
nerdhotrod's Avatar
nerdhotrod is infamous around these partsnerdhotrod is infamous around these parts
And if you has data logged you would see that in 2nd, you would have been in the 1.3 range but the dash is too slow to pick it up. The dash also round .066 meaning if you are 1.234, it will show 1.3. The dash is basically worthless beyond making sure you are making 1.2+ and not .9.
  #70
Old 11-05-2011 | 05:44 PM
johnspeed's Avatar
Yes May be BUT...My car has been data logged alot on the dyno several times >>>And in 2nd gear it showed the that time 1.23 and right after that in 4th 1.37...I guess that showed me that there is a difference in gear and load??
  #71
Old 11-05-2011 | 06:00 PM
johnspeed's Avatar
Which is pretty much spot on for a k24/18g car. Second gear comes up so quickly that it is difficult to make full requested boost.
This isn't mind blowing stuff here. Its common across many makes and models on turbo cars.
That was my point at the beggining when you said about stepping the boost up slightly as the RPMs raise.......
  #72
Old 11-05-2011 | 06:05 PM
FlyingGuy's Avatar
...but the dash is too slow to pick it up... The dash is basically worthless beyond making sure you are making 1.2+ and not .9.
so what is a good gauge? are most using digital or analog(?) type gauges?
  #73
Old 11-06-2011 | 06:04 AM
ttboost's Avatar
When tuning, it's easier to control TQ with timing, than it is with boost...and the factory boost guage is WAY too slow to be accurate for anything.
  #74
Old 11-06-2011 | 12:08 PM
FlyingGuy's Avatar
thats what im starting to understand. i will have to start datalogging for accurate boost numbers. thanx
  #75
Old 11-06-2011 | 09:15 PM
Mpsuk's Avatar
Mpsuk is infamous around these parts
Why dont tuners post their achievments with all the bolt ons and give me a good idea who to have tune mine. If torque is limited down low what is to stop this being an 800bhp car
