Any 10 second 93 0ct.K24/18 cars??
Hey Guys,,Anyone out there running in the 10 second range in the 1/4 mile on 93 oct. fuel or a mix of 93 oct.with Meth with K24/18gs that is still AWD???OR...Know of anyone that has??
Hi John,
I hit 11.0x several times, back when I was only running about 1.2 - 1.25 bar of boost, but never got the couple of 100th's to make it a 10 - I tried many times. I used a mix of 93 and sunoco 104. Now I am running 1.32+ bar and my car feels quicker than ever, but I retired the car from 1/4 mile passes - it's very rough on it. After a few years of hitting the strip and 50 or 60 passes, I had to replace the rear CV joints, transmission mount and front differencial. I think with drag radials and todays current boost levels people are running, an AWD K24/18G car should definitely be able to hit 10's.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
John,
Have you made any 1/4 mile passes with your car yet?
2022 Cayenne White
2022 Cayenne White
Chris Green @ USP, he is on E85 @
1.7 bar ... Not aware of anyone else. Chris has shared info in many of his posts.
Dissio, a 6 speed member who I helped set up the car ran I think 8 back to back 10s on a 18gs, 5 bar, and some entry level add ons... 1.3 bar on 19s with race gas... but he's a heck of a driver...
trapped I believe low 130s...
![](https://www.6speedonline.com/forums/signaturepics/sigpic3357_8.gif)
2001 996TT 3.6L and stock ECU
Mark, not sure if Dissio is the same as Dmaffo? Dmaffo did several 10's in a row like that, but he told me he gutted the car to do it - removed a lot of stuff inside and out and ran catless straight pipes on C16, so he was very light compared to stock. Dmaffo's runs were really good, though and great to watch!
2022 Cayenne White
2022 Cayenne White
Hi John,,Thanks for your info...No,I have not went to the track with this car yet..But that is the next thing on my next to do list... I have ran a few genuine low 11 cars from a 1st gear roll for 'around' a 1/4 mile and beat them by a few car lengths....Having a higher redline is a big plus..But as we all know,,a complete stand still start is a different story for getting the best times at the track.....I shall see because I 'has' to know...lol...
You would think with how long and the number of K24/18gs that are out there,,PLUS with all the supporting mods,,more of those modifiers would have pushed them to get into the 10s...I would think the power is their but the driving and launch is the main key??
John,
The 996tt is a tough car to ET well. It is very difficult to get a good 60' time without drag radials. Once they get going, they are very quick. I have seen mustangs go 10's, but only trap low-mid 120's. If you were racing them, they may make it to a 1/4 mile ahead of you, but right after that they would be in the rear view mirror. For some reason, the 996TT is just not the best 1/4 mile platform. A lot of our cars are set up with additional negative camber for handling and this makes it difficult to get a good 60', which is key to a good ET. I think if you want a really good ET with K24/18G's, you have to set the car up with a mix of a few ingredients such as weight reduction, flat alignment, drag radials, 2WD, high boost, E85 system, etc. - any of those will aid you...
2022 Cayenne White
2022 Cayenne White
def not an easy car to drag race and takes a lot of power to go 10s in this thing. but then again it is 3400lbs. take it to the track john and see what it does !
#TeamAIM
#TeamAIM
These cars are hard to drag race period.. notice how we do not have more 9 or 8 sec runs lol...
GT-R guys are spoiled thats all I have to say...
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
John,
My new higher rev limit does make it easier to go higher in 1st so there is not that big pull down drop when you hit 2nd....
so the verdict is ??
Nobody ever recorded a 10.99 on 93 octane pump gas is what I have learned. That was the question right ?
Change the fuel and then it changes the answer, I believe. Or add meth.
I ran 11.03 @ 134.xx but was always on at least MS103.
