So I decided to paint my grills...
Call me impatient but I had to get it done before I went to sleep. I put painters tarp under the hood covering the fenders, then closed the hood and covered the hood's top along with the driver window and the rest of the car. You can tell by the pics that the plastic wiper cover has faded and appears chalky, weathered.
This Wurth satin trim paint appears to be the exact color as the factory trim. I lifted the hood and I cannot tell where the over spray is compared to the rest of the plastic that covers the battery compartment and other reservoirs. I've got a LandRover LR3 that has a couple of trim pieces that can use this re-coating. This is an excellent way to rejuvenate your cars look. Just take care and take your time.
Probably so... Do you have a link for the removal of the wiper blade cover plastic? I believe it would also involve the removal of the wiper blades which are held by what appears to be a 13+mm nuts. The tarp was quick. The only time consuming part is the tape immediately along the edges of the thing being painted. Everything else is quickly draped and taped just for the sake of wide coverage and hold. I'm no expert in anything car mechanical or DIY related... just wanted to point out what guys can do to remedy the chalky plastic issue and having their cars looking weathered.
I replaced my piece of plastic because it was broken when I bought the car. There is a little cap on each side - visible from the top without opening the hood - with a screw inside. You do not have to remove the wipers at all. I didn't have instructions when I removed mine, I just removed stuff as I went. You do have to remove the two covers inside the hood. Each has one screw, and also remove the battery cover. The piece in question, also has double sided tape holding it in. Just be careful to carefully pry off and it can be reinstalled without changing the tape. The whole thing will take 5 minutes if you really go slowly and are very careful.
Good job, looks nice. Fortunately mine are still black, < 18k miles on the car. The C4S splitter looks good on your car, I may have to do that, I keep scraping mine angling in and out of my sub.
cgunsch
11
11-27-2015 11:20 AM
jaehoppa
10-22-2015 09:17 PM
gadgetman
09-10-2015 03:29 PM
