6speedonline's official 1/4 Mile, 60-130, 100-150 and Standing Mile thread
#1231
Thanks Mike. This was same setup at 25psi on MT drag radials. I have since done some suspension work and installed Guard LSD internals as well as put R888's all the way around in order to get it to track straighter. Now that that's done we were going to go up on the boost but the plugs are already done after 800 miles of C16 so next up is E85 tune. Still looking for my 3.9x
I know it's lame, but I promise to put a build thread together eventually. The car at 1.7bar pulls from BHT at 1.8 bar (although his turbos can go much higher). Mine are probably good for 950whp but spool very early and my redline is 8200.
#1232
How do you like the R888 vs the MTs ? I used the MT 18s before too.
I cant wait for it to get warmer here
#TeamAIM
#TeamAIM
#1233
Mike, add me plz in list
#1234
im really surprised this monster doesnt break 200mph on the mile and only picks up ~50mph during the back 3/4 of a mile. is it gear/tire limited?
#TeamAIM
#TeamAIM
#1235
On that run i was on Hoosier drag radials with less than 13psi, so it was a little bit scary to run more than 200mph. Target was 1/4 mile
#1236
Nice run and certainly impressive car .Curious why your signature says "Worlds Fastest Standing Mile Porsche"?Are u aware that there are a few other Porsches (Bello,Evoms) that are faster?
#1237
Thank you. It will be very good if on Texas mile will be ET timing, not only speed trap. So for now i am not aware about someone is faster
#1238
So, technically, in the mile, your car may not be the "fastest" but it may be the "quickest".
Nice car either way!
It would be great if you could get it to the Texas Mile, but I am guessing that is not very practical for you!
#1239
I think the question is raised because in the states here, when someone says "fastest", they are referring to highest MPH, whereas when someone says "quickest", they are referring to quickest ET.
#1240
#1241
Also, watch out for those who never post times
#1242
#1243
Guys, I have a V.Box Sport and cant see how to log the height change over a run! How do I do this? I spoke to racelogic at the Autosport show and they are going to put elevation change in the Iphone app, I therfore though it was going to be obvious in the Performance Box software.
#1244
Once you bring up the run info on your computer you should have elevation. Then take the total elevation change and divide by the run length to get % change.
#1245
Thanks, I dont have the Vbox sd card at home right now will try when I get to work.
