What does it take to get to 200 mph top speed in a 996 Twin Turbo?
Old 11-05-2011 | 02:00 PM
Snowczar's Avatar
Snowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to beholdSnowczar is a splendid one to behold
Ttheree was a post about a year ago that indicated it would take 531HP to get the TT to 200 mph. That kind of power can be done easily but not cheaply. You're talking doing the "Chip", new exhaust from the headers on back and probably a new MAF. I sugest you talk to someone like Evolution Motorsports or one of the other fine tuning organizations.
Also, if suspension is original I'd look at something like Bilstein PSS10's to steady the car.
John in Vancouver
Old 11-05-2011 | 04:02 PM
Terminator's Avatar
Terminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant futureTerminator has a brilliant future
All you need is a good flash and exhaust. Snowczar also makes good point about pss10's. And make sure your flash raises the rev limiter by 500rpm otherwise limiter will stop you getting there as it stops me at 194mph.
Old 11-07-2011 | 08:40 PM
Meeyatch1's Avatar
Meeyatch1 is infamous around these parts
Originally Posted by nick49
Curious to know, do you want to see 200 on the speedo or know you without a doubt officially traveled that speed?
200 on the speedo is most likely actually between 180-185 mph on a good day. Years ago, 1985 I raced at Bonneville Salt Flats on a Honda 1000cc motorcycle. I did 3 runs and all of them speedo eclipsed 170 mph. My best official was 148.546 mph. My speedo was driven off front wheel. Most all speedos have a built in error factor of around 5-12%.
I am looking for a GPS verified 200 + mph run.
Old 11-08-2011 | 02:42 AM
Terminator's Avatar
I thought near enough is what you were after. Verifed - true - will be difficult. Power is not a problem, gearing is. True 200mph if you look at the transmission diagram is theoretically achieved at about 7,250 rpm in 6th. I know my car with 530bhp /crank, could easily go faster because car is still accelerating as it hits the rev limiter (stock) at 327km/h - 203.23mph - speedo indicated. Some guys up their rev limiters by 500 rpm and I understand they achieved speeds which are a whisker short of true 200mph. What happens if you up the rev limiter even more, for a true 200mph, I have no idea. I think the engine might just explode and create a massive one-off run to 300 mph!!!
Old 11-08-2011 | 02:59 AM
Etahgnimusnoc's Avatar
Etahgnimusnoc is infamous around these parts
So what your saying is our gearing runs out right around 200mph/320kmh?
I also had a question (not to hijack) which turbos would get you to 200 mph in the Texas mile?I have stock k24s and would love to be able to just change out the compressor wheel to achieve this, or is that not reasonable?
Old 11-08-2011 | 06:39 AM
ttboost's Avatar
Having had my 996 turbo to the Mile at almost 200, I would NEVER consider going over 150mph with stock suspension...
Old 11-08-2011 | 08:11 AM
Tim941NYC's Avatar
Great advise and I second that.. There is not much that is needed to reach 200mph in stock form as long as the wind is none existent and enough road is there. My research showed me the stock TT needs about 300 hp to go 200 miles an hour. But we would like to do that in a mile and even worse a standing start. Now I have ran the mile in texas and my car made just under 650 rwhp on a dyno jet and my best time was 191.877. I was on stock tires. What is important is where your power is. When you are topping out a gear you do not have the power you have in the peak. My math tells me that a 3500lbs stock bodied turbo needs about 940-960 ft lbs of torque (in top gear at rpm need for speed) to produce a 235-240 mph standing mile run.
Old 11-08-2011 | 09:51 AM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Convert your turbos to k24/20's.
Old 11-08-2011 | 11:06 AM
20gs , 2nd fuel pump, injectors, good tune for race gas... and of course pen exhaust with decent intercoolers...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old 11-08-2011 | 11:19 AM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Thank you for the replies so far. Some great information, especially the part about aero kits actually harming my ability to hit the higher speeds quickly.
To clarify, I want to be able to reach 200 mph at the Texas Mile, so I guess one could call that the 'brute force' approach to speed. My E63 AMG without the limiter can reach 186 mph with enough road, but something about having that ability to go from a standing start to 200 mph in 1 mile has been calling my name, and I have to get there.
As far as suspension, and getting lower to the ground, I have heard both positives and negatives about coilover suspensions. While these would serve to easily get me lower to the ground, would the spring rates and rebound of the shocks make the car significantly more 'edgy' at super high speeds? The stability of the 911 at high speeds is one of the major pluses in my eyes.
As far as suspension and going 200 @ the mile I had a set of GT2 springs on my car with stock dampers. The car was rock solid from 150-200.
Originally Posted by johnspeed
I believe my car now will do 200mph....I also do believe you would need a higher rev limit then stock to see that,my raised rev limiter did help......I have had it to 181mph on my speedo[ its probably higher because of the 1'' bigger dia. tires] hitting the rev limiter in 5th and then in 6th 'pulling' still to 190mph but ran out of room.....Can not wait to see 200mph,,,so does the traffic cop that will be hiding/waiting for me somewhere .......lol......
Having seen a number of attempts on 18g's and running them myself I just don't think the 18g's have quite what it takes. The extra top end of the 20's will get the job done if the conditions are right.
Bottom line: Going 200 @ the mile is a minimum $20k investment.
Old 11-08-2011 | 11:32 AM
Frank ( Sunnyside )'s Avatar
Frank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond reputeFrank ( Sunnyside ) has a reputation beyond repute
K1639's Turbos
soft intake pipe
60 lb injectors
decent exhaust
Decent IC's
Tip box
Decent Tune for 1.5 bar
EBC gain 6% set gain 0.0
Pump Fuel ( 93 absolutly no additives or race fuel)
200.77 mph GPS verified in 1.4 miles on a 1.5% incline.Oh and it was still pulling hard when I had to hit the brakes.
Standing start 0-200 mph ( gps) 34.17 seconds. Was reading 206 mph on the dash!
Lap after Lap after Lap after Lap....................... In Fact the only reason I stopped was my standard brakes were smoking and I mean smoking.
Suspension is new PSS10's ( fantastic btw)
Old 11-08-2011 | 11:41 AM
DNugget991GT3's Avatar
i have k24s, rwd, my car is SLAMMED.
i hit 202 CONFORTABLY on jones beach. my car makes ~500rwhp.
if memory serves right, this was on a 315 michelin.
i run 305 30's now, so it will probably be good for another ~8mph , right tim ?
Old 11-08-2011 | 12:05 PM
johnspeed's Avatar
I am pretty sure I will be able to do 200mph on an open road area,,,not a standing mile run with my mods...As metioned before I have had it up to 190mph on my speedo and it was still pulling but ran out of road...
Old 11-08-2011 | 12:08 PM
ttboost's Avatar
Yep...about right. When I did it, I had about 600rwhp (Mustang dyno, so about the same as a dynojet at 650rwhp) I went 195 and there was a crazy side wind about half track...
Old 11-08-2011 | 12:14 PM
bmoores's Avatar
That wind was brutal. That was a good weekend though.
If we are talking running 200mph with endless road you can do it with a flash most likely. I thought I saw you ask about doing so in the standing mile ..........
