Race Gas
Race Gas
If I run 100 octane gas in my stock turbo will I see any differance in performance? I found a station in town and wanted to know if I was wasting my money or hurting the car by running 100 octane gas.
I would probaly mix it with the 93 as it is 4.00 a gallon here. Input please!!!!!
Eric
Eric
Re: Race Gas
Eric
Eric
Regards,
Evan
Originally posted by LSM
Can you use race gas if you have a modified ECU? In other words, is the modified ECU only meant to operate at 93 octane or less?
-Lou
-Lou
Regards,
Evan
PS-Duane where do you get the 100?? VP Fuels?? That is where my buddy got the bad gas, be careful if that is where you go!!!
Originally posted by AMG ETR
Yes you can, I asked the same thing awhile back, Stephen and others said its fine...
Regards,
Evan
Regards,
Evan
did you ever try it? I mean is there any advantage?
-Lou
Evan,
-Lou
Evan,
-Lou
However!!! I have heard it doesn't burn as well, so you have to drive very sprited for it to be effective...
If you are not going to be driving hard then it was not reccomended.
(This is what I have been told)
Regards,
Evan
I have not tried it yet...nearest place to get it for me is 30 mins away, however I will be in that area tomorrow, maybe I will pick some up.
Regards,
Evan
Regards,
Evan
-Lou
Lou...
I agree with Hamann!!! I run it if I can get it, if not I always try to have some in the tank to achieve a higher octane rating to be safe. usually 1/2 92 and 100 octane. Works very well.
Tyson...I also changed to Motul Ow-40 yesterday per Wilbur's recommendation and my car runs a lot happier now. excellent stuff
I was thinking it may be a good opportunity to gas up with some 100 octane at the Tail of the Dragon meet in North Carolina. Does anyone know if there is a station in Asheville, NC that has 100 octane? They simply don't sell the stuff in NJ.
Hamann...
Yeah...Motul is pretty difficult to locate, but hey...Wilbur has the hook ups!!! I actually brought some back from Hong Kong and it was cheaper than here in the states.
100 octane and Motul 0w-40...wow, our cars sure live the good life
As far as tuned cars go such as Stage X what I understand that going to race octane of say 108 or higher will not make that much difference unless you have a program you can switch to for that octane. With the chipswitch you could have a 93 octane rating and then another program of 108 or whatever. So I don't think in a modified car above 100 will make much difference unless you have the ECU programmed for it.
