First time durametric logs... what do you guys see?
so ordered a durametric and did my first logs this A.M. i think i did it right. either way, these are getting emailed to Todd K so he can evaluate my current non-proto tune, and see what we need to do when i switch to his sauce. I can figure my tune is far from ideal, but until i get used to them, these numbers seem like "The Matrix" to me... thoughts? and i recorded 10 parameters, which apparently wont post properly on a PDF, so i had to manuever it around. but these were the parameters that are usually logged, per my findings on this forum:
RPM
Engine load
Intake air temperature
Ignition angle
Oxygen sensing bank 1 or 2
Lambda setpoint, B1 (AFRs)
Adaption, range 2 (FRA) bank 2
Boost pressure of sensor
Injection time
Throttle position sensor 1
here ya go. also, aside from critiques on the data, any info on how to more easily log or post data would be helpful
quick info
40*F weather
flat-ish road
3rd gear only
996tt A28 turbos, old evoms/giac tuning, 60# injectors, 91+meth, evoms IC, evoms boost hose, evoms vflow w/ hitachi, fvd inlet pipes.
RPM
Engine load
Ignition angle
Injection time
quick info
40*F weather
flat-ish road
3rd gear only
a touch lean as indicated by your o2 sensing bank 1. The DME is commanding 0.80 lamda under full boost/load and its settling in the high 0.8x range. might want to log bank 2 as well. love those meth IATs!
