Car trailer guys: Advice needed
What is the minimum length I should consider in an enclosed trailer (to haul the 996TT)? I've found some new 20' enclosed Haulmarks in the $5500 range, Is this a good deal?
Depending on how much stuff you want to carry, I would consider 20' a minimum size. I had a 20' carrying an e36 M3, and it was a bit tight with a tool box and additional tires (on a storage rack).
I think a 24' is just about perfect for a single car, and still able to be towed by a reasonable vehicle.
Just my $.02.
Jon
Just my $.02.
Jon
Good points. Any drawbacks to a flat "open" trailer?
Just my $.02.
Jon
Just my $.02.
Jon
Security, lack of built in storage and exposure to the elements are the big downsides.
In my 20' trailer, I had a built in rack for 8 wheels/tires (track setup and rains) and a roll-on/roll-off tool chest that was strapped down and pretty much lived in the trailer.
If all you are doing is getting the car to and from the track, and you have a limited tool set that you can throw in the back of the truck, then an open trailer is good. You can even build a tire rack on the front of the open trailer to transport your rains/track setup, but I wouldn't leave them out in the hot sun in between track weekends.
Really depends on what your goal is. My car was a dedicated racecar, but I started with a 16' open, then built a rack, then bought a 20' enclosed, then a 24' enclosed, then bought another car and bought a 48' enclosed for two cars (but then you need a 1 ton truck to pull it). It's a snowball.
My FAVORITE trailer i have EVER owned was my 24' TPD enclosed. Triple axle, amazingly easy to tow, very good build quality.
I'll thrown in an additional vote for the 24' enclosed as my the best compromise between a manageable size and adequate storage in my opinion. Properly set up, you can tow it with a current full size truck (Ram 1500/Silverado/F150) or larger SUV (Suburban/Excursion) but still have adequate room inside for the car, tools, easy-up's, tires and a decent work area. Once you move up to 28', you pretty much need to be in HD truck territory to comfortably tow.
I'd also suggest looking into aluminum trailers. I've got an ATC Aluminum 24' trailer that weighs in +/- 1000lbs less than most steel 24' trailers and that lets me stuff more gear inside of it while still staying comfortably under the 9000lb tow capacity of my 1500 series Ram.
Tal
Tal
Do you know if my 4.7L Tundra could handle the 24' with the Pcar and some gear?
Tal
Tal
You'll need to add a transmission cooler if the truck does not already have one, a good trailer brake controller (I like the Tekonsha P3) and a good weight distributing and sway control hitch system.
Edit - it is not like the world will end if you exceed your towing capacity by a few pounds, especially in a chassis where a larger motor gets you a larger towing capacity, but I personally like to keep my towing limits a few hundred pounds under the max. I've done a lot of towing in excess of the stated limits - but that was towing a 3000lb boat with a Jeep rated at 2000lbs (which is rated at 4000lbs everywhere else in the world). When you are talking about pulling 4 tons, I take the limits a little more seriously as the consequences of a problem are proportionally larger.
Tal
^^ What is the tow rating of that Tundra as equipped?
I always recommend 'derating'... although they may SAY "6000 lbs" (for example) life at 6000 lbs will suck. 25%? Pick your number, but give yourself a margin.
IMO
A
IMO
A
Go enclosed and go as big as you can. The only problem with trailers is where to store them, if you don't have a little land to play with. You saw my 28 foot enclosed when I was in Texas. I hauled my TT and 2 bikes with a sh*tload of gear half way across the country, never had to worry about security and everything sat in my trailer for a few days after I got home too....
I'm going to tow the car to events like Texas Mile and The Texas Invitational.
PorscheEnthusiast
11-13-2015 02:23 PM
