Tapping transmission case for GT2 slave conversion
#91
With all of this talk of rod length, has anyone considered making an adjustable rod? Seems like you could take the stock one and fit a threaded sleeve and locking nut to come up with something that would allow for adjustment. Am I crazy? Seems like different clutches sometimes do require a change in rod length - yuck.
#92
it doesn't matter what length rod it is until you get so short it pushes out of the slave. its hydraulic. whatever the length the fluid equalizes it with pressure and engages it. i tired longer and shorter no difference. engagement is affected by the pressure plate and throwout bearing. only way to effectively change the distance os to have an adjustable clutch pedal
#93
I think I follow, so perhaps an adjustable rod into the clutch master then? I've not ever had to pull mine so I don't know if that's feasible either - locking nut would be captive ;-) Other platforms can adjust clutch take up and I know some cars I've had the rod into the master has had to be tweaked. My RSTi has an adjustment up under the dash that's apparently a pita and needs to be tweaked. I think a rod that was sleeved and threaded might be better but I don't know how much compression force it's under. Fiddling bore sizes and whatnot seems a bigger hassle.
#95
#TeamAIM
#TeamAIM
#96
Wait a Sec? Does the Piston rod length change the travel of the pedal? Top to bottom distance is what I am referring to.
If I remember correctly, I think Tim or Prodigy completed this mod once before.
#97
no it doesn't
#98
No it doesn't. We thought it might but it doesn't change it.
#TeamAIM
#TeamAIM
#99
So changing the rod at the slave doesn't change engagement point, surely doing it at the master should right? If not what the heck governs the take up other than the clutch disk and PP? Seems like master rod length should effect it...
#100
it can. would be easier to make an adjustable pedal though. since my install of the triple disk clutch my pedal is way high. since the gt2 conversion its at least in the same spot ewvery time so its easy to get used to. just to much work to change and as the clutches wear down the pedal goes with it
#101
On another note, Thanks for the clarification on the rod length 32krazy and prodigymb.
#102
My setup must be different. I have the GT2 slave conversion with the 3x rep and the friction point is at the top. Prior, it was in the middle. I have a 997 btw. Not that the model should matter On another note, Thanks for the clarification on the rod length 32krazy and prodigymb.
#103
#104
Elite has the Evoms bracket. Don't know about 32crazy. Wonder if the bracket has something to do with it and whether if having the box drilled and tapped as OEM would change the engagement point.
