What are the factory boost levels by 996 turbo model?
HI Steve,,,I am confussed here??What other info are you looking for....I believe you did get your answers to you opening question....Also,there are many topics on this if you do a search......It is really not that hard of a question which was answered....Just trying to understand what other help you need to help.....
I did search and it wasn't as easy to sort through the information and get the anwers as I thought it would be. Of course maybe I just stink at searching.
The only answer remaining is the boost level on the later 2004-2005 GT2 cars that were rated at approximately 480hp.
Later, Steve
stock vs stock.... no x50 996 package car from any year will be as quick as the TRUE 2005 S car. this has been said many times in other threads/posts
and i've ran against 4-5 x50 cars and the results have always been the same at the track in 1/4 mile. I've heard hp is the same on the TURBO S as gt2 at480 hp
dont like reiterate...what is your requested boost from ecu with durametric?...0.8-0.9 with 1bar wastegates is only base boost...check this and you have one answer
Attach zip is the Durametric log file, the DME was requested to boost 1.3 and it actual boost is still 0.8.....
Larry, site won't allow me to PM a response to you so I put it in this thread. I chose Kevin at UMW based on online reputation, reasonable price but mostly due to numerous phone conversations with him and his straight forward answers to my questions. Everything worked just as he told me it would and I have been very happy with the results.
afr look good, so i would check n75 valve mechanical and electrical,(durametric actuators test) diverter valve and hoses...at the end a boost leak test
wish you luck ....there is a lot power difference between 0,8 bar and 1,3 bar...
okay a real bad situation...your ecu cry for 1,3 bar and you get only 0,8
How do I know it is failure or fine using the Durametric to test the N75 value?
Besides, my DVs and hoses were newly installed 5000 miles ago. But I have the P0492 come back always, therefore I could hear the secondary air-pump is working during engine cold.
Thanks mate, its quite annoying to me now.
Possible causes:
- Fuse faulty
- Open circuit to secondary air injection pump
- Short circuit to ground in the lead to the secondary air injection pump
- Secondary air injection pump relay mechanically faulty
- Secondary air valve sluggish
- Secondary air injection pump (air cleaner) blocked
- Air hose to secondary air injection pump slipped off or is crushed
- Secondary air injection pump faulty / stuck
...you can test with actuators active check secondary pump and valve .....
you can check n75 with durametric and activation actuators....you hear click noise from your n75 valve if it works electrical..mechanical test is you check the ventilation of the n75 valve...no voltage full pass from y pipe to wastegates
with voltage no pass to wastgates but ventilation side open
check ventilation hose if it is free and open
after all above the most common failure is a boost leak.....https://www.6speedonline.com/forums/...-pressure.html
hope it helps and excuse my bad english....
Hey Steve (OP),
I'm actually a bit surprised that you felt the modified K16 car felt strong, coming from your background. My own modified K16 car doesn't have that top end power that we're used to from Supras, but has a much more progressive midrange that makes up for it. I generally liken my powerband more to a naturally aspirated V8 than a turbocharged 6, and that is even with the factory exhaust. I'm on the verge of installing a more free-flowing exhaust and do look forward to feeling how that amplifies the powerband a bit more. I hope you find a suitable 996TT soon as I know you've been looking for a while, but I think you'll be really happy when you do.
i forget someting, you should also do a datalog from both banks, left and right...maybe a different afr show you a failure ore boost leak
do a hard push in a higher gear and log both banks......
Got it and will do, thanks dude. Will update the log here again after recoreded.
