Giving up 6 disk changer if switching to aftermarket DVD nav system?
Yes and No. You can jerry rig the factory junk to work with an aftermarket double din unit, but it won't sound for ****. If you're going to do it, replace everything (amps, speaks, etc).
+1 - it will work by just replacing the head unit and removing the OEM AMP. The AVIC Z120 BT has about the same power internally as the non-Bose OEM system, but you will hear a noticeable improvement if you get a new amplifier as well.
04-28-2022 12:38 AM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
