No O2 Readings
No O2 Readings
Hi Guys,
In the process of mapping with Proto. Todd says he does not see any O2 readings in my log files. Any ideas what could be causing this. 1 of my Pre cat Sensors is brand new, the other has 45Kmiles on it. Lambda readings are fine and the ecu sees the sensors plugged in, just no O2 readings?? I've checked connections and secondary air pump. Used Durametric to run secondary pump manually. All works fine. Any help would be much appreciated as I am STUMPED!!
maybe you never checked them off to be logged?
2001 996TT 3.6L and stock ECU
The issue is.....the O2 readings are 1.00 forever and ever, regardless of revs or gear or load or speed or anyting. They flatline at 1.00 and stay there.
I suggest that you post a log from a boost run, and then you might get some more helpful responses.
Jon
Why not post precisely what you sent to Tony?
Posting a different log will not answer the question of why what Tony got is no good....
I think you got it wrong... it needs to say "Oxygen sensing bank 1 Lambda Value".
you are logging the wrong values..
Interesting. So what he ticked was "tell me the status of the Oxygen Sensing" ...which was "on" or "1"
What he wanted was the actual values....
thats what I'm guessing...
