Cable Adjustment For B&M SSK?
Old 07-11-2012 | 09:02 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Originally Posted by ant_8u
It was very slow to 'centralize' itself - when you wiggle the shifter whilst in neutral it wouldn't spring back again very quickly
I have no issue at all with the spring in neutral.
I was always very slow when shifting with the B&M
The reasons for this firstly the notchiness, but also the fact that it wouldn't spring into neutral very quickly meant it was easy to miss shifts
Going from second to third I'd miss the gate and the shifter would hit between the first and third gate
My personal technique for the 2-3 shift is to push the shifter to neutral with my palm, allow the spring to center the shifter directly under 3rd (exactly what the spring was designed to do), then push the shifter straight forward into 3rd (still with an open palm); a "push-pause-push" movement. The shifts are smooth, fast, and accurate. I believe the most common error in missed 2-3 shifts is when drivers attempt to make it a "straight line" from 2nd to 3rd.
Old 07-12-2012 | 08:46 AM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
Yeah, I use the same method
Going from 2nd to 3rd I put my open palm on the gearstick at a 7 o'clock position
My hand is behind the stick, not on top of it
By doing this the shifter finds its own way into neutral
Like you I spent sooooo long adjusting the B&M in my car
I think it was an improvement over the the 996 shifter, but compared to the 997 one I think it's now junk
I know it's all personal preference though
Did you try, and dislike the 997 shifter, or have you stuck with the B&M?
Old 07-12-2012 | 09:25 PM
Very true.
I've driven the 997 shifter in other 996 Turbos. For my tastes, it is not short enough in terms of throws, and is not solid enough in overall feel, especially at the end of each gear (gear stops).
The B&M is not perfect, as it requires some effort to make the 2-1 downshift when the transmission is cold (no issue when the transmission is warmed up). But once warmed up, I couldn't ask for anything better.
VID997
97
03-20-2018 02:23 PM
nick49
01-26-2017 01:17 PM
mantruck
02-19-2016 05:23 PM
Fadi
10-05-2015 12:14 AM
Quick Reply: Cable Adjustment For B&M SSK?
