Cable Adjustment For B&M SSK?
Old 01-16-2012 | 12:50 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
I'm not happy with the feel of my shifter
I think I can make improvements by adjusting the cables
I see the 997 shifters come with the tool to centralise the shifter
This tool isn't provided with the aftermarket kits
Does the centralising tool fit onto the aftermarket shifters in order to provide correct adjustment, or Is there another way to work out the ideal adjustment needed?
Old 01-16-2012 | 02:33 PM
deckman's Avatar
O think it will fit. How will you adjust the cables? Do you have an idea how you are going to do the adjustment? I ask because I may adjust mine also.
Old 01-16-2012 | 03:24 PM
johnspeed's Avatar
HI,I could never get my BM to shift that smooth or good when it was cold..I even had the Porsche dealer readjust it to the best that they could...I went to the Porsche 997 short shifter and it was worth it.....
Old 01-16-2012 | 03:37 PM
ant_8u's Avatar
I'm pretty sure I'll switch to the 997 shifter too
I'd just like to try adjusting the B&M one first
I doubt it'll make any difference, I just want to be certain in my own mind first
Old 01-16-2012 | 04:15 PM
gearhead's Avatar
gearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond reputegearhead has a reputation beyond repute
I marker my cable before I removed the oem shifter. When I installed my b&m I just matched up th lines I marked on the cable. Three years later no problems.
Old 01-16-2012 | 04:31 PM
deckman's Avatar
I had the B&M on my old car and have the 997 SSK now. I marked the threads like the DIY said to do but still think it could smoother.
Old 07-08-2012 | 07:01 AM
ant_8u's Avatar
OK, I've just got a 997 shifter from someone fitting a SSK to their car
The shifter I got doesn't have the centralizing tool
Do I need to get this before making the switch, or can I just install it as-is by marking the cables length first?
Old 07-08-2012 | 07:08 AM
ant_8u's Avatar
Just seen Scottslaw did his install without the tool and said it went well
What's everyone else think?
Old 07-08-2012 | 08:36 AM
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Exactly what I did, but I also have the evoms shift linkage.
Old 07-08-2012 | 09:13 AM
pwdrhound's Avatar
The Porsche centering tool will not fit fit the B&M shifter...
Old 07-08-2012 | 03:45 PM
ant_8u's Avatar
Thanks everyone
I just replaced my B&M with a 997 SSK
Didnt come with a centralising tool as it was used
I used the markings I made when I installed the B&M
Everything's lined up nicely - and the 997 shifter is so much nicer
Old 07-09-2012 | 12:31 PM
Tim941NYC's Avatar
Damn I have a spare tool I could have put in the package. lol I have the 997 ssk sitting in a box waiting for the rest of my project to catch up.
Old 07-09-2012 | 12:37 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
I have the B&M now, not too thrilled, was it worth the time
to go to the 997 shifter ? Did you install the 997 SSK or just the regular 997 ? There have been some threads recently with many not very happy with the 997 setup, so I'm a bit confused on how to proceed.
Thanks.
Thanks everyone
Old 07-09-2012 | 02:26 PM
ant_8u's Avatar
My opinion is that the 997 shifter is superior to the B&M shifter
As far as whether it's worth switching from the B&M to the 997 - For me, yes it was
The B&M shifter was very notchy
It took a lot of effort to get it into gear
It was very slow to 'centralize' itself - when you wiggle the shifter whilst in neutral it wouldn't spring back again very quickly
The 997 shifter is not notchy at all
It takes very little effort to get into gear
It centralized itself far quicker
As far as the difference in throw is concerned - When in 1st, 3rd, or 5th gear the shifters move forwards about the same amount
When in 2nd, 4th, or 6th gear the 997 shifter moves further back than the B&M shifter
I was always very slow when shifting with the B&M
The reasons for this firstly the notchiness, but also the fact that it wouldn't spring into neutral very quickly meant it was easy to miss shifts
Going from second to third I'd miss the gate and the shifter would hit between the first and third gate
With the 997 shifter I can shift far quicker with less effort and due to it popping back into neutral quicker it's impossible for me to miss shifts
The longer travel isn't an issue at all as the 'feel' of the 997 shifter still allows you to shift quicker with it
The 997 shifter isn't life changing
It isn't the best, slickest shifter in the world, but it's definitely much improved on the B&M shifter
Old 07-11-2012 | 08:53 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Once the transmission is warmed up, my B&M with EVOMS shift linkage is spot-on and smooth; as "rifle bolt" as you can get with cables. I personally wouldn't consider a different shifter.
I was however **** about adjusting the cables when I installed the B&M...
Quick Reply: Cable Adjustment For B&M SSK?
