Picked up my car from Cary Eisehlohr yesterday...
Old 05-18-2005 | 11:55 AM
ColorChange's Avatar
ColorChange is infamous around these parts
John: Elaborate on you background please.
  #32
Old 05-18-2005 | 12:14 PM
john stephanus's Avatar
john stephanus is infamous around these parts
Okay...hope this does not come off in a self-aggrandizing way...
Started in karts in 1979 and then went on to Formula Ford. Started FF with the Russell School's rental program in 1980. Was the factory driver for the Viking Formula Ford team in 1981 and 1982. Rookie of the year in my region in '81 and then Nor Pac Formula Ford Champ the following season. Drove Pro Super Vee in '83 and '85, with a year of Russell Mazda Series in '84. Was asked to race in what is now Indy Lights by an established team in '86, but the financing package just did not come together. Tested a stock block powered Indy car for a rookie team in 1989, but the team never put it together.
  #33
Old 05-18-2005 | 12:40 PM
Gratzy and impressive.
So, I should assume the R's you sold me are shot from heat cycling right?
  #34
Old 05-18-2005 | 12:50 PM
Seriously though, Tim, you should think about doing the RSR crossmember/rear carriers and the mono-ball control arms. I think these are the basis of curing the handling problems with the turbos. Then an awesome alignment. BTW...working with Cary reminded me of working with Carroll Smith.
  #35
Old 05-18-2005 | 12:53 PM
Zippy's Avatar
John, I think it's time to change your status from "Senior Member" to "The Beast".
Mike
  #36
Old 05-18-2005 | 01:11 PM
I already have Cary's solid arm mount disks (replaces the dognut in the rear). What else do I need for sure?
  #37
Old 05-18-2005 | 01:53 PM
Hamann7's Avatar
Porsche Fiend
Hamann7 is infamous around these partsHamann7 is infamous around these parts
Congrats John, you will have to give us a full report.
I've said it many times before, Cary is the best!!!
Cary, is my car next?
  #38
Old 05-18-2005 | 01:56 PM
buddyg's Avatar
Tyson,
Have you done any mods to your GT2 or is it still stock?
  #39
Old 05-18-2005 | 03:02 PM
In my estimation, the GT-3 control arms with mono-*****, the RSR crossmember/rear carriers. Also, I do not know if you already have ERP adjustable links...they are necessary I believe. Really Cary would be the person to best answer this though.
Cheers...
  #40
Old 05-18-2005 | 03:06 PM
Thanks Tyson...I mentioned to Cary that he should put out the ERP Turbo! Would be the car for a shootout I think
I think it would really be fascinating to see a GT-2 done by Cary and compare the differences...
  #41
Old 05-18-2005 | 06:13 PM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
John, how is the ride quality with all of the rubber removed on the suspension attachement points?
1. Can you feel a qualitative difference?
2. Does the car get resonance through the chassis on rougher roads?
Thanks!
P.S. I had a 993 C2 that ultimately ended up with close to what you've done to your car. Dropping the suspension on these cars without changing hub carrier centers can sometimes cause side effects.
And lastly for all of us here. How about some pictures?
  #42
Old 05-18-2005 | 07:19 PM
Thanks!
The ride quality is surprisingly good. Not to say that there is not a little more noise and roughness...but I just drove from LA to Seattle in the car with my fiance. We left on Saturday and got home mid day on Sunday...stayed the night in Ashland. Neither of us felt that the car was uncomfortable.
Will run the car up on my local mechanic's rack over the next couple of days and post the pics I take.
Cheers...
  #43
Old 05-18-2005 | 08:28 PM
Hamann7's Avatar
Porsche Fiend
Originally posted by buddyg
Tyson,
Still mostly stock.
  #44
Old 05-18-2005 | 08:29 PM
Hamann7's Avatar
Porsche Fiend
Yes indeed... he and I have been wanting to get started for a long time. It's what I would call the GT2-RSR project.
One advantage of the GT2 is that many of the Motorsport parts adapt much easier to the RWD platform.
  #45
Old 05-18-2005 | 10:27 PM
cjv's Avatar
cjv
Moderator
Originally posted by Cary Eisenlohr
John's car also has the RSR front cross member which raises the roll center and modified rear RSR carrier supports... I think that really helps when you have the ride heights most of these cars are using... If you were to just measure the supports to the ground, Johns car it won't reflect exactly whats going on because they have been moved up higher into the chassis. This is where a lot of the numbers don't make since when measuring from car to car. These units on a GT2 are in a different place from a stock turbo so if you measure from the sub frame of a GT2 and a TT then measure from the wheel opening to the ground they won't be the same.... On John's car those same numbers would be different again. When doing John's car I wasn't concerned with where the frame was to the ground but rather the roll centers and how the the roll couple correlated to the Center of gravity on his car at it's weight and weight distribution. I know it sounds like a bunch of babble but there are some sweet spots on these cars and they do vari depending on a lot of things. The exact set up on Johns car wouldn't necessarily be the sweet spot on a lighter car or a car putting down different HP. I think his set up is much more the right direction and I still feel there is more tweaking that can always be done and then as John says, he likes a bit more oversteer than most which is fine if you have the driving experience he has... for others I might stay without as much oversteer ... but the fun thing with John's car is this... remember that old video of the Ruf Yellow bird on the track in Germany doing those oversteer burn out exits off 70 mph turns?? well you if you want, it's easy to do that with Johns car if you over cook it just a bit with the psm off. The difference being, it feels like all four wheels are lit!! Oh btw... again... sorry about your brand new tires John .... but it was fun... Honestly you can throw that car at a turn.. think you know you're going off the track and still save like you never missed a beat... I didn't think a turbo would work like that... but I was wrong...
Cary,
I guarantee you all four wheels spin in a turn when you defeat the throttle body shutdown.
Oh .......... you did redrill the frame to lower.
Quick Reply: Picked up my car from Cary Eisehlohr yesterday...
