Coolant pipe repair. Parts needed....
Old 03-22-2014, 08:30 PM
Hamilton996's Avatar
Hamilton996 has a spectacular aura aboutHamilton996 has a spectacular aura aboutHamilton996 has a spectacular aura about
I am rebuilding my engine and I am having them welded
  #197
Old 04-12-2014, 12:19 PM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
Originally Posted by jpflip
I know some people have used epoxy glue for the anchors. I also had one of my Wej-it becoming flush with the floor but I realized the inside of the column needed shims because the floor was uneven due to the drain being in the center of the garage... . After shimming everything was stable….
My install went well other than the anchors setting in slowly. I followed the instructions to the T. After a few lifts the anchors finally settled. See picture. Still affraid to get under the car
  #198
Old 04-12-2014, 03:45 PM
jpflip's Avatar
Very good job Al!!!!Don't worry , it took me over a year before I was feeling comfortable to work under the car!!!!LOL!
  #199
Old 07-27-2014, 02:24 PM
mhall1019's Avatar
mhall1019 has a spectacular aura aboutmhall1019 has a spectacular aura about
Weld or pin?
I've heard that those lifts from Amazon have an issue with the hydraulics that can be fixed by either pinning or welding. Another option is to pin it and then weld the bolt in place.
JP- So, when were you going to tell me about this coolant hose issue? About a month ago, I stated a project (the 100kmi 100 hp/lb-ft bump up) including new injectors that were really going to be hard to do with the engine in, not to mention water pump and hoses, etc. I started thinking about dropping the engine and while I was looking around the forums, I ran into this coolant hose thing. So, its been decided - I'm going to drop it - slowly, I hope.
I have a lift, but that doesn't solve all the problems from what I can see. It seems like the best way will be to get the engine/trans assembly loose and then lower the car down to a hydraulic table, take all the bolts out completely, and then lift the car off the assembly on the table.
Something else I've been thinking about is taking the cross-member and the transmission mounts with the engine. The assembly will then rest on the tranny mount in front and the cross member in the rear, which are nice flat surfaces which will be resting on the nice flat surface of the table. I'm going to check one more time to make sure this can be done and then do it. One thing that this may help with is the problem with lining the assembly up to reinstall, which I've heard is a problem.
Lastly, I'm quite sure I'm going to do the pin job. I don't have a complete picture of this in my mind, but it seems like going all the way through with a bolt would be the best way. I don't think the metal chips from drilling is a real issue if done carefully. The only thing that would be a real problem would be sealing the fixing bolt (or pin). I have never in my whole life been able to get anything that comes in a tube to seal or glue two things together successfully. Except for Loctite 574 for sealing and gluing case halves together.
Thanks again for being a great resource on another 996t project. I'll keep you posted - not sure if this is the right forum - it seems to be car lift/engine removal/pin or weld all-in-one forum, which is OK with me.
Mike
  #200
Old 07-27-2014, 03:15 PM
jpflip's Avatar
Porject...
Good project!!!
Yes it is the best way but remember to lower the engine about 4 inches and take care of disconnecting the components on top of the engine, fuel hose, brake vacuum hose, coolant vent line, intake distributor assembly etc.. and after you can lower completely….
Never done it like that but heard it can be done….
Mike, think about it…It is a big job to remove the engine and pinning, imho is not "the" final solution….I am not a fan of glue when it is in contact with heat but I'm sure there has to be a proper glue out there but Porsche didn't know about it...….
Welcome, always a pleasure to help TT owners and keep us inform of your project! J.P.
Mike
  #201
Old 01-12-2017, 04:05 AM
Kriss16's Avatar
Kriss16 has a spectacular aura aboutKriss16 has a spectacular aura aboutKriss16 has a spectacular aura about
How did you guys get the turbo oil return pipes off the waterpump housing?
Mine seems to be stuck.. It's two o-rings on each of them, need them off to replace destroyed pipes.
Any advice, heating or something or is it just to prepare for drilling them out..
3 pipes going in there (to the small pump) and would be nice getting the big one off without destroying it..
  #202
Old 01-12-2017, 06:13 AM
jpflip's Avatar
If you look at page 4 post 53 you will see that I had to scrap the lines....I only try release oil but did not work. I did not want to use heat because of the rubber seals near the turbo scavenge pump....Finally I discover the fitting were seized on the lines and turning the line (rest of it) I was able to take it off the reservoir. The other side need to be soak in release oil and shake a lot and finally came off.....Of course I had to order two new lines ;-(
  #203
Old 01-12-2017, 07:00 AM
Kriss16's Avatar
Thanks..
Ok. Just soak oil and power then..
  #204
Old 01-14-2017, 08:32 AM
Kriss16's Avatar
Got them out but not without a fight..
One was completely stuck so had to think good..
The end of the pipe is 16mm, and the pipe itself are 10mm.
Drilled a 10,5 mm hole, made M12 treads and put a M12 bolt in to get a good hold and finally it got loose..
  #205
Old 01-14-2017, 08:45 AM
jpflip's Avatar
Very good job Kriss!!! Congratulations!!!
audipwr1
09-25-2021 01:31 PM
PenguiN
10-26-2018 07:23 AM
orbelo
08-30-2015 12:26 PM
Vrseis
08-20-2015 07:41 AM
Quick Reply: Coolant pipe repair. Parts needed....
