Coolant pipe repair. Parts needed....
#108
Tim, I am now planning to go to your shop for a deep heart surgery ;-) I need to see a specialist, like you, installing a crankshaft, sleeves, pistons , timing the cams and taking you out after for a beer!!!!
#113
Superb thread!
I have what may be a dumb question but when you pin the pipe you drill right through the whole pipe? Does this not drop some bits of metal or swarf inside the pipe. Is all the coolant flushed out then, or is this not an issue.
Also can anyone point me in the direction of an idiots guide to pinning these pipes, which screws, sealant etc. I wont do it myself but love to understand the whole process just to keep my workshop on their toes.
Many thanks!
Many thanks!
#114
Carlos, you will found answers to your questions in this excellent thread started by Dan@ Sharkwerks:https://www.6speedonline.com/forums/...ark-werks.html
Post#16 about metal shavings....Also some people are using grease on drill bits to catch the shavings....
#115
In the repair on my car, the motor was out and the parts were removed, so there was no problem to catch and remove all of the turnings. It's only an issue if you try to do the repair in situ.
Jon
Jon
#116
Reviving an old thread but just did a little exercise . For DIY mechanic out there, for the coolant pipe welding job, you got all the part# (updated may last year 2012) that I've order + prices I've paid (Sonnen). Of course may be you don't need all of those but it can help locate the ones needed and give you an idea of what's the cost. Sorry if I forgot any but did my best to help. The total is $335.17 including all the rubber hoses. Of course that is in the better world. I had to include 4 oil lines for the turbos that were seized on the water pump housing, a water pump because one impeller was broken, thermostat housing because I dropped it by accident and also I've replaced all the hose clips and clamps ...
999 707 410 40 o-ring coolant temperature sensor housing+ 3 other coolant pipe housing 4 $2.75 ($11.00)
999 707 411 40 water pipe housing 8 $4.14 ($33.12)
996 106 214 70 protective ring 4 $5.13 ($20.52)
999 707 505 40 fuel black o-ring line 1 $4.14
999 707 506 40 fuel beige o-ring line 1 $8.27
999 707 364 41 oil reservoir check valve o-ring 1 $ $1.38
996 106 340 71 water pump gasket 1 $7.46
996 106 326 71 thermostat gasket 1 $2.48
999 707 315 40 water pump housing o-ring 1 $1.38
999 707 468 40 water pump housing o-ring 1 $4.14
900 123 144 30 coolant drain port seal 2 $1.04 ($2.08)
999 701 789 40 oil cooler housing + oil lines to turbo o-ring 8 $0.57 ($4.56)
999 707 422 41 o-ring oil filter bracket 1 $4.14
999 707 426 41 o-ring oil filter bracket insert 1 $4.14
999 707 113 41 oil cooler bracket insert o-ring 1 $2.75
999 701 789 40 oil cooler bracket oil line 1 $1.75
999 707 446 40 oil cooler bracket oil line o-ring 1 $1.38
999 707 409 40 oil cooler o-ring 4 $1.38 ($5.40)
996 107 217 70 oil filter housing gasket 1 $3.74
999 707 298 40 sterling pump housing o-ring 1 $2.75
999 707 204 40 o-ring steering reservoir 1 $5.49
996-106-328-74 coolant hose 1 $27.46
996-106-477-75 water hose supply 1 $17.92
996-106-529-73 coolant hose 1 $6.39
996-106-512-74 water hose 1 $15.64
996-106-250-74 water pump hose 1 $10.34
996-106-233-74 water hose 1 $10.08
997-106-502-00 collant hose 1 $23.88
996-106-501-77 collant hose 1 $24.95
996 106 801 03 o-ring 4 $3.21 ($12.84)
996 106 318 02 throttle gasket : 1 $4.94
996 111 217 70 exhaust ring 2 $23.56 ($47.12)
900 123 152 30 o-ring 2 $0.77 ($1.54)
996 110 318 02 throttle body seal.($6.11)
#118
Yes, great information to post, JP! I am sure many will find it very helpful.
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
