996TT K24/18G fuel Support - exhaust
hello speeders ,
one of my friends is running k24/18g with stock fuel system ,he is ran out of fuel if we get more than 1bar of boost ,
i would like to get bigger injectors and UPGRADED FR !!
so what do you suggest ? and whas your recommendations ?? he just looking to get 600whp only , it is just safe to run enough fuel !
something else what is the best exhaust to fit the k24 and has aggrasive sound in WOT ?
thanks in advance ,
Yousef
thanks in advance ,
Yousef
5 bar or injectors.. that's easy...
Exhaust? well you have many options...we some high quality hand made in house exhausts...
best
markski
best
markski
2001 996TT 3.6L and stock ECU
hello speeders ,
thanks in advance ,
Yousef
thanks in advance ,
Yousef
With a 5 bar fpr I was told that you are good to 1.1 boost on 18g's at 1.2 your running out of fuel then. I wouldn't run more than .9 on a stock fuel system. If your trying to achieve 600 whp your not going to do it with a 5 bar fpr. But for a quick fix in the meantime get a 5 bar in there ASAP! I would go with 72lb Bosch ev14 fuel injectors with the stock 3.8 fpr. You'll probably need a second or larger fuel pump to get to the 600 whp range. Tell your friend to talk to his tuner and he will suggest the best option for him. A setup like johnspeeds should get you there with a catless exhaust and 100+ octane gas. I almost have the same setup minus the extra fuel pump and other odds and ends johns got. I think he's near or above 600whp on pump gas. Good luck!
With a 5 bar fpr I was told that you are good to 1.1 boost on 18g's at 1.2 your running out of fuel then. I wouldn't run more than .9 on a stock fuel system. If your trying to achieve 600 whp your not going to do it with a 5 bar fpr. But for a quick fix in the meantime get a 5 bar in there ASAP! I would go with 72lb Bosch ev14 fuel injectors with the stock 3.8 fpr. You'll probably need a second or larger fuel pump to get to the 600 whp range. Tell your friend to talk to his tuner and he will suggest the best option for him. A setup like johnspeeds should get you there with a catless exhaust and 100+ octane gas. I almost have the same setup - the extra fuel pump johns got. I think he's near 600whp on pump gas. Good luck!
Now my next thing, I am going to try on the dyno,to see if it helps,A 74mm throttle body and a Protomotive modified stock Y-pipe that matches up to the TB...
What boost/HP levels did you run out of fuel at? I'm worried I'll experience the same fate here soon.
Hey,Do you mean when I had to go to the extra 044 fuel pump??
Yep!
Also -- how did you notice lack of fuel? Fuel trims start creeping higher than .83 in the logs?
All this happened after I switched from the CarGraphics to Milltek exhaust....I did a thread on this back then....hope this helps.....
HI,When my car was being data logged on the dyno,,, The A/R was lean but my 72 injectors were not near their max duty cycle..So,we put a fuel pump pressure gauge on the fuel filter while we did a dyno pull and I noticed that the max pressure went down as the RPMS went above around 5800rpm,as I recall.So thats when we knew I needed another pump..
If you fit bigger injectors e.g. 60 or 72lb, keeping the 3.8fpr, you can run 1.35-1.38 bar max and your fuel duty cycle will be less than 100% all the time. As soon as you run over this your injectors will be at 100%, but importantly they will want to be open even more, although that is not possible e.g.107% at 1.45 bar.
Don't run larger injectors with 5fpr - that is a no go. Stick the 3.8fpr with injectors.
You could also swop the std fuel pump for a Bosch 044 at the same time. That would give you a little more coverage.
A 5fpr + Bosch 044 (no larger injectors) would be okay for about 1.25 bar. No more.
The above is on 18gs.
HI,IMO no..I looked at all those avenues when I needed more fuel....Just put the 044 pump inline and you will be good to go for the extra fuel...Marski has under the car kit..You can do a search and look up my thread on it..Mine is under the car also....Good Luck...
