Trouble finding 315/25/19's. Anyone else?
#91
ZOokie- are you not rubbing? My car ( same as yours) looks about as low as yours on a 12" rim my PS2' on rear in 315/25/19 barely has clearance and can look even tucked in the back from some angles. I know depending on sidewall construction ( taller, rounder, etc..) I "THINK" I can run 305/30 but just wondering..
Also it is verified I do have to run 225/40 in front?
thank you anyone..
thank you anyone..
With a 315/25-19 that's a 25.2" height you need something taller and the optimal size would be the 235/35-19 at 25.5". Of course these measurements vary slightly from tire to tire brand/type but in general these are pretty close. A 225/35-19 would be the same exact size at 25.2" but again that varies by tire so you could end up with something that's slightly smaller, which you don't want. The 225/40-19 is going to be too tall at 26.1" to go with the 315/25 rear so you definitely want the 235/35-19 to match the 315.
#92
thank you anyone..
thank you anyone..
