Anyone with 20g's.
#31
NO,,The Stock Y-pipe is being modified now by Todd to match up with a 74TB ..I have the stock connections for my larger AWE hoses on it , as their intercoolers output side is larger then stock...I run 1.3 bars and 1.4 peak in higher gears and cooler outside temps.....I messed up with this phone,I thought I was replying to Justin, sorry..
#33
I've got clipped k24/20g, stock intercoolers. I went with Markski's intake piping, and i spool about 300 rpm later then the k24's I had, but it pulls soo hard. Not laggy at all. I run upto 1.3 on 93, although I've had inconsistanies maintaining a steady boost. I think I may be running on the limits of the stock fuel pump. I dont have any dyno numbers, but i can tell you it gets upto 190+ pretty quick.
#TeamAIM
#TeamAIM
#34
back in the days my partner's 20g made 680whp... if I recall correctly... on a blow thru on 100 octane at 1.5 bar. I drive it a handful of times as well.. a 6 speed member bought... in minnesota... I know he did run some Evoms 800 kit and he can tell you the rest
2001 996TT 3.6L and stock ECU
#35
I'm on larger injectors, 660's or something like that, honestly I can't recall. Stock y pipe, 911 tuning bendable intake piping. I'll be doing plenty of racing this season ( highway, and 1/4) The car has a Marski/Promotive flash. even at 1.0 bar it pulls way harder then the k24's. I'm also on stock boost hoses. In my oppinion the 20g's are perfect.
#37
All I know is my K24/18g set-up with this Protomotive tune is very smooth also and very potent.....Hope the 74TB,plenum and modified Y-pipe helps more....LOL..
#38
We aren't too far apart
