Impressions with the New Front Splitter
Yeah i know been awhile. Been real busy the past few months. Hopefully i'll have some more time soon.
OH my... Do I say anything.
I have watched both threads (this one and the creation of thread)...
All I can say is that the product does not look like it belongs on the road nor does it look like it belongs on a classy car. I also think it creates a serious safety issue... It is a poor attempt at a good idea.
Also you curb it while parking or whatever and the way it is bolted in will not end well for the front of your car.
Simply put I think it looks ugly, heavy and like a cheezy after though bolt on.
Sorry to sound negative.
A good product that does the same thing could be developed but lets face it; how big is the market for such an item.
First off, this product was designed for improving the performance of the car on track, not for street use. We do understand that most people will use these on the street, so that was taken into consideration, but as a secondary design criteria. The look of the splitter is based off the function. It was designed to maximize the surface area while keeping within the wheel base of the car and still allowing for ease of use when exiting ramps/driveways. The shape you see is putting function before form, something that track people will understand.
The splitter is not very heavy, about 8lbs, so closer to 9lbs with the hardware. It attaches at the rigid mounting points under the car using strong hardware, where it attaches to the lip, the material is quite thin so it would tear away the bolts before breaking the lip off the bumper. We have already had one splitter we were developing fail/bend at high speeds and we have learned from the failure and made it much stronger. If you crash or go off track with the car, you should expect damage just as you would without the splitter. It will cause less damage though compared to a single piece splitter/lip combo like was suggested before.
Since most owners that would consider this splitter have cars too low to clear a curb, we are not really all that concerned about what would happen if you hit the curb. If anything, I believe this would minimize damage because you would hear it begin to scrape before you hit the bumper/lip. The mounting points below the car are all on very thick metal, so the clips we use would break before they would bend.
As for it being a cheesy afterthought, you are entitled to your opinion, but just know that this is designed for performance, not looks. Every aftermarket part for the car is an afterthought, the point is to design parts that maximize performance while maintaining the functionality of the car. In that aspect, I believe this is a complete success. Obviously you do not think this is a good design, and you are obviously not the intended user, the people who want a splitter know what they are getting into and know what to expect, they are typically not idiots. Aye
I myself would fail a car with that thing on it at any track day I was associated with.
Here is a link with hundreds of different pictures of Porsche cup cars. You find one image that has some "Heavy" aluminum plate bolted to the undercarriage for a front lip. http://www.google.ca/search?q=porsch...w=1116&bih=680
Front lips get ripped off all the time; in either minor collisions with other cars or whatever.
And for the regular driver when I said curb it I meant pulling into the local Starbucks for a latte. Ram that thing into a parking curb and you have messed some stiff up; badly too. A speed bump, a curb and track curbing are entirely different animals.
Until they closed my local track last fall I would make 6000 +_ miles a year on just my local track on both bikes and in cars, if I am not the intended user then you tell me who is.
You want front down force there is none better than Pikes Peak cars. Now the monster sure has character too
and here
http://www.google.ca/search?q=porsche+cup+cars&hl=en&rlz=1T4GZGN_enCA433CA433&prmd=imvns&source=lnms&tbm=isch&ei=fVFMT6bCDoiZiQLk5vC9Dw&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CBEQ_AUoAQ&biw=1116&bih=680#hl=en&rlz=1T4GZGN_enCA433CA433&tbm=isch&sa=1&q=race+car+front+splitter&pbx=1&oq=race+car+front+splitter&aq=f&aqi=&aql=&gs_sm=3&gs_upl=3718l4538l3l4698l8l8l0l0l0l7l251l1468l0.1.6l7l0&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=f545de8fddceece5&biw=1024&bih=665
I see you edit your post, anyways' look through those pictures and you will see the splitters are mounted towards the back of the front facia. If you "race" you should know the splitter that sticks out portion is only half of the battle. The true test is how far back it goes to keep the low pressure. Also i'm positive the cup cars must use the same supports I used or else theirs upsolutly no way the splitter will stay in tack, or flat at high speeds. Maybe they will stay in tack if you drive and park at starbucks but that's about it. Even before we had the supports we have now , my prototype failed at 160mph and no damaged of what you speak of. The screw's will give out before the supports do.
http://www.google.ca/search?q=porsch...w=1024&bih=665
I see you edit your post, anyways' look through those pictures and you will see the splitters are mounted towards the back of the front facia. If you "race" you should know the splitter that sticks out portion is only half of the battle. The true test is how far back it goes to keep the low pressure. Also i'm positive the cup cars must use the same supports I used or else theirs upsolutly no way the splitter will stay in tack.
Light Weight Composites....
On none of those cars do I see an 8 lb plate of aluminum.
Even this one in the link below is cut from a poly carb sheet, weighs ounces not lbs.
http://waterjets.org/index.php?optio...=176&Itemid=31
This thread went south pretty quick. I'll give you the point of view from the casual observer. Obviously very popular guy posts picture of his new splitter. All his friends like it, guy not in the click thinks it's ugly. Friend of original poster calls guy that don't like it an idiot and insults his heritage. Guy insulted doesn't realize he was called an idiot or doesn't care. Maybe he actually is the idiot after all, aye? One of original posters other friends joins the site just to reaffirm that the guy that didn't like the splitter must know nothing about cars.
This is too much to keep up with.
For me an AWD Turbo is a better car than a GT3 because I no longer have a local track, it has been bulldozed; so my car will mainly be used for all weather on road vehicle.
Nice first post BTW....
Guy who called me an idiot is the guy that actually made the product.
You hit the nail on the head "This idiot really does not care"
Sorry F1, your front splitter does have great potential, just make it out of something other than metal.....
I'm not calling you an idiot. Read carefully. Also, this contrustive critism is much better than your first post on this thread. Constructictive cristim is welcome as I can improve the product and make it as the client desires.
I will give you an idea that would be real cheap, light and strong enough. Cheap styrofoam sheet wrapped in one layer of fiberglass. Its shapeable and workable. You can make it the exact shape as the item you already have now. You want even better use some aerospace type honeycomb.
You will be seeing a custome made wing and front splitter gracing the front GT2 bumper of my car some time in the near future. You can critique my work all you want then.
That's what happen when you get old and have to go to sleep early; I missed all these excitement.
What I see so far was most people concerned about the safety of others, which I agree. You do need to consider how you drive and where you drive when using the splitter.
Some obviously think that it is ugly; I don't think it is ugly but my car does look better without it. When I purchased it, I was thinking... if it doesn't work, I'll just leave it in the garage. But the trip home really surprised me, so I decided to keep in on for awhile. I may still remove it later and only use it when doing group drives.
In terms of the thread going south, I have seen it many times when people start calling names. OhioC5, please, next time, re-consider before calling people names or try to stir it up. Although, people are expressing their points in disagreement, but they are still healthy conversations.
The "pedestrian I didn't see" scenario is obvious, but what about (for whatever reason) losing this off the car at 70 mph on a busy interstate? Would the rear tires kick it up at the car behind you? Seeing an 8 lb aluminum scythe blade whirling at you at a high rate of speed sounds... unappealing.
