Weird Clutch Slippage??
Hey Guys,I never encountered this type of problem with a clutch....When the cars sits for a period to totally cool it down in this cool weather,like overnight stay,,The first few times I get into full boost in 3rd gear the clutch slips....But after those intial slips,,it will not slip anymore, even in 4th gear under full boost..
I always thought that if the clutch was starting to go, it would get worse when it warms up more?? Is there a seal in the clutch area that could slightly leak fluid then get around the clutch suface area and then get burned off?..
My luck,when this started to happen,I was suppose to go to Kelly Moss that week to do the TB swap on the dyno.....
Any help would be appreciated,,Thanks..
I agree! Then it warms up and gets sticky. It could also be the small increase in pressure when the system warms up that adds to that. You are making nice power, perhaps testing the stage 2 clutch.
John,
From my experience, that's how it is when they begin to slip - it starts in the cold....IMO, you need a new clutch. If you recently put one in, you need a stronger one. I have gone through this...
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
2022 Cayenne White
Hey Guys,Thanks.I have about 17,000 miles,2yrs,lots of dyno pulls and countless/numerous full throttle power shifts on it...
Also,even if the car gets full warmed up and I go on the highway then,continuous cool air flow.....It will slip the first few times under full boost and after that will not.....
Hey ,maybe this would be areal life dyno test now>>If I put the bigger TB ,plenuem and modified Y-pipe on to see if it slips worse or stops slipping....LOL..
sounds like its on the way out. Baby it, take some time to find a replacment. Careful with some high performance clutch, some are very stiff. I didnt like the hard clutch in traffic. Became a real pain.
Hey Guys,,I know that temp and power go hand in hand on turbo cars...BUT its just unbelievable that>>Today the temps were in the upper 70s and no clutch slippage in the same driving conditions that caused it to slip when it was in the high 30s and low 40s.....I did not do any hole shots to confirm real slipage but I did my full throttle power shifts with no slippage at all today ....I am putting a clutch in tomorrow though....Trying the Sachs Performance GT2 style,unsprung, over the ClutchMasters one,sprung..Same pressure plates..
I had that same thing happen on my old Subaru STI. It started slipping sometimes (not all the time) and by the time I got to the shop (2.5 hours away back then, a lot of mountains where I had it) the slipping got very bad. It was the clutch (and had to replace flywheel too).
When it starts slipping it gets worst quickly. The fact that the clutch is fine when it warms up can mean that your clutch is 'just about' to go toast.
probably clutch is going and/or glazed flywheel. my stock clutch did the same thing, until it just stopped holding 2nd gear and up. my recommendation is dont keep beating on because it will ruin the flywheel. my flywheel had 16k miles on it and was completely shot because i drove agressively on a slipping clutch.
#TeamAIM
#TeamAIM
HI,Its finished,just came back from shop with it....I put the Sachs Performance 883082999764 pressure plate and the 881864001098 special GT-2 style disc in....It feels great !..Better feel then my previous CM set-up..I do not have the GT-2 conversion...But how long will it hold??,we shall see... I am happy with it.Will put miles on it today..
On my old CM set-up the pressure plate was very badly worned
/grooved on the outer surface diameter about a 3/8'' width all around and badly glazed on the inner diameter about a 1/2'' width all around..
On the flywheel side it looked amazingly good..Just some material build up which came off with brake clean and very slight glaze marks in spots that were cleaned up with an abrassive pad...It was flat and straight....
Disc had a pretty good amount of material on it.Except for the grooved and glazed parts on the pressure plate side it looked fine...
