Any value in keeping the emergency spare?
I thought about it today my car is lowered and if I ever had a flat that couldn't be fixed with the compressor and sealant I would call a tow truck . I don't think I would want to risk using the spare. I know wonder if it is worth leaving in the car?
Has anyone driven there lowered car on the temp spare.
I have had that same thought and came to the same conclusion that i would call a tow truck. There are 2 more good arguments to not have it. If the flat is on the rear, there is no way in hell I would put a donut back there and also where are you putting the flat tire and wheel after you put the spare on? I'm not putting that dirty wheel and tire inside. I guess you could argued its good to have in case you get stranded in the middle of BFE with no cell service and that's all you got to get you out of there. Just my thoughts
If you do decide to remove the spare remember to retain the tow hook that screws into the bumper. That way the flat bed driver will have no problem loading the car.
BTW .. one of the first things I did was remove the spare. I am thinking that will be a great spot to relocate the battery. another project for another thread.
The spare can't be used with the spacer, so to avoid having to lug around those standard lugs?
When you think about it, why not???? The spare being a very small tire, there should not be any rubbing or any kind of problems. But never tried....
My guess is the spare will probably fit with the spacer, but just in case. I have two sets of OEM lying around in the garage anyway.
