Making a go at repainting calipers and wheels myself.
#31
Have some updates. Things are going very well and some of the doubts I had going into this are now gone. Caliper paint looks awesome. I've been spraying from about a foot away and it is going on pretty smooth. I'm waiting on my PORSCHE stencils but have the red complete. I experimented with the Wurth paint as some of you have warned me. It is quality stuff but it has to be used a certain way. You have to spray it really fine and from a foot distance. It is like sprinkling dust on the wheel, really light coats. The flakes settle in the can easily so you need to be constantly shaking it. Half of it flies into the air but it is looking awesome. I'm going to clear these tonight and get the tires mounted tomorrow. Really happy with the wheel paint.
Sandblast preparation, cannot get any better prep. Easy and inexpensive to do.
2 light coats of primer and about 3 coats of red, looking great.
Primed and sanded several times. The Wurth primer is nasty smelling stuff, blew a few brain spraying this paint.
Fine flake dusting lays rough so that when you cover it in clear it pops out at you.
Looks factory so far, clear coat later tonight.
#32
Everything is looking great. Like I said before, with enough patience you can make it look damn good. Quick question though... please tell me there is some tape over those pistons/seals? They look exposed but hopefully I'm wrong. Not for certain but you may experience piston failure on your caliper if the paint is inside and all around that aera.
#34
Nice work! My front brakes look like shiza. Luckily the previous owner had Porsche refinish the wheels do still in great shape. Talked to the body shop that redid by headlights and will refinish by brakes later this season.
Good luck with the rest of the job and congrats for taking this on!
#35
Great job w the Wurth pain on the wheels. I never could get it to lay flat like that. Probably was going to heavy and too fast. Or I just had old bad paint. That must be it - yeah. The paint's fault.
Nice work.
Nice work.
#36
Welp, doesn't look like the wheels are going to work out for me. Props to those who warned me not to do it! The clear isn't coating over and glossing like I'd hoped it would and the silver is a bit too fuzzy. This paint might be better for restoring a classic Porsche. I'm going to take them in and get them blasted again. It looks decent, but that's not good enough for this car. The calipers are going to work great as long as the paint doesn't melt. Still waiting on my PORSCHE stencils.
#37
#39
The wide flat areas on the turbo twists accentuate any imperfections. I had better luck when I did my BMW wheels that have much narrower spokes. BUT, a couple years later the paint has cracked/chipped in a couple areas AND the clear is starting to yellow. My takeaways: (1) Wurth paint isn't "all that" and (2) you'll never get great results with a rattle can in your garage
#40
It looks like you are taking the right steps with prep..... just get a nice HPLV and compressor. Make a "booth" out of plastic sheets, and go to a body shop supply and get a respirator, and paint/solvent/clear. Ask them for mixing instructions for the temp / humidity you will be spraying in.
Here is a pic of a TechArt 993 Bumper I did years ago (in my garage). Looked like a factory spray, when I was done!
PelicanParts.com
08-18-2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-18-2015 03:42 PM
air, automotive, blast, brake, caliper, calipers, compressor, condition, conditioners, factory, media, powered, repainting, ruin, silver, vbulletin, wheels
