I think I found cheap 19's for Tracking - need advice
Old 10-21-2003 | 12:58 AM
fredttx50's Avatar
fredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond reputefredttx50 has a reputation beyond repute
Question I think I found cheap 19's for Tracking - need advice
After having no luck finding cheap 19" wheels on all the Porsche Forums, I was about to give up. Then I went to Ebay and found a set of 19"s for only $1370.
EdgeRacing
I think they actually look very nice. For this price I would consider buying these. This way I don't have to remove my 15" Brembos.
Any advice about this company would be appreciated.
thanks,
Fred
Old 10-21-2003 | 03:32 AM
buddyg's Avatar
The problem is there are no good track tires for 19's. What tires are you going to use?
Old 10-21-2003 | 09:03 AM
20C4S's Avatar
fred,
be careful. these MAY NOT clear ur BIG brake kit.
i have a set of EdgeRacing wheel for my mini in the for sell forum. reason is the same, couldn't clear the huge brake. knowing that is different car, this might not be the case, but better do some research b4 pull the trigger!
in this case, i think only custom made wheels can solve the problem, like my Kinesis u'll call that's close...
Old 10-21-2003 | 09:14 AM
Jack(LA)'s Avatar
Moderator
Jack(LA) is infamous around these parts
Fred:
Assuming you can find adequate track rubber for 19" wheels, these are not the ideal width/offset for your car, especially the rear at 10" w/ET40mm. Also, at 29+lbs they're pretty heavy. I'm pretty sure that you can order some 18" Kinesis or Fikse non-reverse wheels with the proper width/offset that can clear your brakes and have a wide selection of great track rubber. Of course, the Kinesis/Fikse wheels will cost a tad more that $1350.
Old 10-21-2003 | 09:34 AM
oak's Avatar
oak
Fred, Why not just put on the stock brakes? It's easy to do. did you sell your stock units?
04-28-2022 12:38 AM
MadWhip
09-03-2015 02:04 PM
Sales@RSW
09-03-2015 09:34 AM
Zero911
08-24-2015 06:51 PM
Quick Reply: I think I found cheap 19's for Tracking - need advice
