flex disc
Old 03-25-2012 | 08:43 AM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
flex disc
changed the flex disc the other day. this was just part of the winter upgrades. the disc was very cracked. 996 turbo 2001 with 75k miles.
Old 03-25-2012 | 08:58 AM
landjet's Avatar
What is it? What does it do?
Old 03-25-2012 | 09:10 AM
pat's Avatar
pat
that is the connection between the output from the transmission going forward to the drive shaft. it is located under the transmission mount. i am sure mine is not abnormal for a 2001. most likly anybody with a 2001, with close milage and an original flex disc will have the same thing.
Old 03-25-2012 | 10:29 AM
jpflip's Avatar
Any part# or is it the part everybody is getting from Florida?
Old 03-25-2012 | 10:32 AM
jpflip's Avatar
To answer my own question: https://www.6speedonline.com/forums/...haft-part.html
And to be more precise: http://www.koperformance.com/catalog...Flex-Disc.html
Old 03-25-2012 | 11:06 AM
pat's Avatar
pat
i ended up getting mine here. the place in florida just dident get back to me. i called 4 times over a week.
http://www.ebay.com/itm/Porsche-996-...item3f15334bbc
here are some more
http://www.ebay.com/sch/i.html?_from...All-Categories
Old 03-25-2012 | 04:37 PM
landjet's Avatar
Question, is this rubber part the main component that handles the torque transfer to the front wheels?
Old 03-25-2012 | 04:43 PM
RennFab's Avatar
RennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of lightRennFab is a glorious beacon of light
Part known to most as a guibo joint. Takes up shock load in the driveshaft and isolates driveline parts from slight misalignment under load(keeps vibration down as a result)
Common to see cracks in them with age. Used on many others cars too, like BMW's and the like.
Old 03-25-2012 | 04:48 PM
pat's Avatar
pat
All the torque to the front wheels goes through that donut.
Old 03-25-2012 | 05:08 PM
m3ntal's Avatar
Senior Member
m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !m3ntal Is a GOD !
known as a "guibo" in the bmw world...change it out as regular maintenence
Old 03-26-2012 | 05:07 AM
landjet's Avatar
Pat, were there any symptoms that led you to change this, or did you just see that it was cracking?
Glasgo
11-30-2015 02:37 PM
LIDB9
09-12-2015 04:28 PM
Quick Reply: flex disc
