Another K16 billet build
#48
That is alot of timing and mid range A/F ratio is definetly on the lean side until 5000rpm. Maybe for now bump up the size of ur meth nozzles or add another nozzle.
You should really look into getting a fuel system for your mods.
Boost looks like they kept it between 1.2-1.3 bar on peak.
One thing for sure is you gotta love the IATs on Meth.
#TeamAIM
#TeamAIM
#49
I just updated the log with boost, I was worried about the timing to... doest the ECU adapt by itself? so timing will advance until knock? I hear about the ECU adjusting to race gas after a few runs, I assumed this is how it does it?
#51
Here is your high boost and A/F log that you sent me .... graphed.
#TeamAIM
#TeamAIM
#53
no problem. here is the low boost log you sent me. still kinda lean...
#TeamAIM
#TeamAIM
#55
One thing I don't know is how 50/50 meth/H2O affects the AFR and how you tune for it, from what I gather you typically tune leaner since Det is not a problem and EGT temp also drop at least 200F. I am injecting 20%-25% of total fuel system capacity at full chat so this gives me a lot more fueling capacity so the WHP#'s may not be that far off?, food for thought anyway. Scott/Softronic has tuned a bunch of 996TT's with meth Inj with great success so far and I am far from qualified to second guess him. We will see how long it lasts
#56
Man that is a good bit of timing! Boost comes in pretty late for a K16 as well, I would expect 1 bar about 1000rpm earlier. Did you leak check it after assembly? I have a turbosmart EBC as well, you can get rid of that little spike with some tweaking.
