Clutch master stage 3 break in?
I'm guessing modded as the technition didn't mention anything. lol
I did the EVOMS GT2 clutch mod and a LWFW (964 RS) at the same time as well the engagement is perfect, the ultimate mid HP range clutch setup in my opinion. Engagement is so smooth and easy.
Yes same here,, did the evoms slave conversion and LWFW (964 RS) with the Clutchmasters FX300 HRFF as they recomended 20-934-HRFF. 4500 miles later its slipping No track time no new Dyno time) Driven to work and back mainly.. Some second and third gear hard pulls,, about it.. My clutch is all the way at the top. It was like that before the changes with the dual mass FW and a Sachs clutch that also only lasted 6k miles.. When I purchased the car the clutch was slipping soo happened to 2 differant drivers/owners.. 3 clutches and only 22k miles :/ Any ideas of what to do next guys?
running same clutch w/ fibre tough (evoms gt2 slave conversion + lwfw). recall manual recommends 500 miles under X rpm. Mixing rev range/load up with city stop/start driving rather than highway is better. 3 years 10k km and still going strong. but I never do drag style hard launches.
High pedal can be from the new setup and the length of the slave rod. May need to be cut or lengthened to change the pedal height. Two clutches in such a short time may be driver error. Try not riding the clutch as much.
High pitched sounds from lw/fw are a harmonic resonance and are prevalent in most twin or triple disk clutches. Learn to live with it
ECS Tuning - VW
09-03-2015 09:43 AM
