Clutchmasters/EVOMS stage 3 slipping !!!!
#46
Thanks for the input, the clutch I removed did not have this band I had just over powered it. I have pics somewhere I will try to find again. I didn't try to cut corners the porsche shop I go to charged me over $1000 to install the clutch I didn't tell them to cut any corners. I am going to measure the clutch disk to see inconsistency's in the thickness.
I am also checking the reassure plate and flywheel for consistency/ flatness.
#47
#48
The flywheel and throw out bearing came as a set for Kevin @ umw I assume it was correct I will have to check, it worked flawlessly with the old clutch until I upgraded the turbos ext and the it gave out.
sdg1871
12-24-2015 12:22 PM
ECS Tuning - BMW
BMW Vendor Classifieds
09-21-2015 08:18 AM
ECS Tuning - BMW
09-16-2015 03:02 PM
