Widest front tires?
Old 05-15-2012, 10:55 AM
Ms4cd's Avatar
Ms4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond reputeMs4cd has a reputation beyond repute
Widest front tires?
What are the widest front tires we can use on an 19 inch wheel?
Due to restricted tire manufacturing in R compound the below are my choices:
225/40ZR19 89W
235/35ZR19 87W
245/40ZR19 94W
I am RWD so no need to compensate with rear.
Thank you.
Old 05-15-2012, 11:11 AM
03 996tt's Avatar
03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future03 996tt has a brilliant future
I run a 265/30/19 and its lowered with just springs.
Old 05-15-2012, 12:24 PM
Engine Guy's Avatar
Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !Engine Guy Is a GOD !
Any issues or rubbing at all, I was contemplating a 255/35-19.
Please anyone else on here that has good knowledge if that size works, I think with my adjustable trailing arms I could compensate with a small tweek forward if that did not kill the geometry badly. With my 245/35-19 I now get the slightest rub on the back of the wheel well liner.
Ms4... I now run a 245/35-19 on a lowered car and I get the slighest rub when turn 3/4 lock; it rubs on the wheel well liner. The tire you are considering (245/40-19) is bigger so I would think that would be worse.
Old 05-15-2012, 12:40 PM
DNugget991GT3's Avatar
it depends on the tire itself.
an R compound tire usually runs wider than advertised.
for example a Toyo T1R (street tire) with a 235 35 19 measurement, will be SIGNIFICANTLY smaller and narrower, and have a more "concaved" sidewall profile compared to a Toyo r888 in the same size.
here is a toyo street tire
heres another one https://encrypted-tbn3.google.com/im...3rhm4F8NUnQwla
here is a toyo R compound (notice how the shape of the sidewall compared to that girly street tire
Old 05-15-2012, 12:41 PM
dont put a 255 30 19.
the added 10mm are negated by that extra sidewall...
a fair compromise is to run a beefy 245 35 19.
Old 05-15-2012, 01:12 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Not a direct answer to your question, but If it's for the track I'd go for some used 18" rims. You'll have wider choice of R compound rubber at a lower price.
Old 05-15-2012, 01:45 PM
03 996tt's Avatar
I have not noticed any rubbing. I will say turning the wheel takes more effort than it did with the 235's, but havent encountered any other drawbacks other than the added weight.
Old 05-16-2012, 06:08 AM
landjet's Avatar
I'm still AWD, what rear tire will match up with a 255 front in 18's?
Old 05-16-2012, 09:10 AM
ard's Avatar
ard
ard is offline
265/35 is good with 315/30... but need 9" rim
OP- you need to tell us what rim width you have.... if you can go to 9" more choices.
And why 19" for track?!?
COBB Tuning
11-09-2015 08:02 PM
oufan2929
11-08-2015 08:26 PM
L.A.P.
10-19-2015 10:01 PM
Sales@RSW
BMW //M
08-26-2015 06:41 AM
L.A.P.
08-23-2015 11:48 PM
Quick Reply: Widest front tires?
