P/S hose leak
P/S hose leak
So I noticed a few drips of Pentosin on the floor of my garage the other day. Turns out the power steering pressure hose is leaking from the upper "quick disconnect." It appears that the inner o-ring (the one near the black plastic circ- clip) popped out of the "quick disconnect" connection.
So that brings me to my two problems. First, the "quick disconnect" does not quickly disconnect I've tried unscrewing it using two 15mm open end wrenches without any luck. It's a very tight space (I haven't tried lowering the engine yet) but I've been able to get some good torque on it and it didn't budge. I think heat would help but there is a lot of plastic and wiring around it and the joint is covered in pentosin... so I'm very hesitant to use a torch. Anyone have any tricks or suggestions on how to disconnect this line?
Even if I get this thing apart, the inner o-ring doesn't have a separate part number. The "quick disconnect" is around $109 and I'm not even sure it comes with the o-ring (it may be part of the hard line). Anyone have any insight on what I can buy to fix this leak?
I really don't see any easy way of fixing this thing. I'm tempted to just cut the damn joint off and use a swagelok tube fitting and some AN braided steel hose.
Do you think it had anything to do from when you had to remove it in order to disassemble the PS pump itself.
I have a extra geen seal/ o-ring. i weld up my PS and tank and am only using the pressure line.
One I get the o-ring out I'll measure it and see if that green one will work.
Josh/AWE
04-02-2020 05:38 PM
ModBargains.com
996 Turbo Vendor Classifieds
10-01-2015 11:48 AM
drkbrent
10-01-2015 07:30 AM
6speedonline, 996, disconnect, hose, houseambuilt, porsche, power, pressure, ps, quick, removal, replace, replacing, steering, upper
