0 to 60 times with modded 996TT Tipronics
0 to 60 times with modded 996TT Tiptronics
What kind of times are you guys getting with your modded 996 TT Tiptronics?
IIRC, it's the Mercedes 5 speed auto box, so Renntech and others can build it if need be.
didnt know that but the m/b auto is pretty well bulletproof to 500 hp and more with the e55 . they see over 600 ft/lbs torque which is what kills the trans when modding. my search is just beginning and still deciding what path i want to go. 996tt or cayman turbo'd auto is preferred but manual could be done.
That is really moving! Just out of curiosity what is the fastest you have done in your manual?
When I was organizing my mods ('04 996 TT Cab Tip) with EVOMS they advised me the Tip was the same as the one in the SL65 except for being 4 wheel drive). That car has over 600 Ft lb's of Torque I believe. The indicated that the TIP could take up to 1,000 lbs which seems a bit high to me. We stopped at 550 lbs for my car. I did go for the reprogramming of the TCU to match the ECU tuning and other mods. Transmission does seem to shift better with this upgrade.
John in Vancouver
John in Vancouver
Wow! He had to have done some major tranny mods! I have heard to stay under 550 to be safe!
