Anyone running 315 R888s on 12 inch rim?
Old 06-04-2012, 02:38 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
Originally Posted by n360rb
No spacers,I had to do some homework tho...Tire Rack sells them in TT and GT2 offsets. I determined that the GT2 offsets were the ones i needed for 315 and 235. They fit perfect with Mich 315's and 235s. No rubbing and flush.
Great info thanks!
Your on 18s correct?
Do you know what the offsets are?
Old 06-04-2012, 03:02 PM
Barth's Avatar
Barth is infamous around these parts
Originally Posted by GT2rainge
Thanks for the information, when I need tyres next I will get 335/265.
I'm getting 997gt2rs intercoolers so can modify them to make the tyres fit at the same time, did you find them better over 315 on track?
I have always run mpsc but now no 315 anymore.
I have also run with MPSC earlier before they closed down the production of tires for "old" cars ...
No street approved tires in Europe can compete against the MPSC when it's perfect conditions!
My car is built for track use only with a lot of modifications: Ohlins racing chasie CUP and RSR wishbones CUP diff and flywheel EVOMS K24 ...
I was at the Nurburgring, a month ago and I had problems with wheelspin in certain high speed corners +200 Km/h with 315 Toyo ...
I changed to 335 and got rid of that problem completely :-)
The higher profile made ​​them unreliable in the sideways movement of the extremely high speed + 250km/h it can get better when I have had a few heat cycles in the tires.
I run 245/40-18 in the front to get to the roller circumference fairly correct.
I know that 265/35-18 will fit in the front but I think it was tight with 245/40!
Old 06-04-2012, 03:08 PM
Barth's Avatar
996 gt2 and turbo rear wheels have the same offset,et 45, it's just that the gt2 wheels are 12" and turbo wheels are 11"
Cheers
It is true but remember that the GT2 has rolled back and front fenders from the factory!
Old 06-05-2012, 11:35 AM
TurboTodd's Avatar
Originally Posted by LiNks
I also run 315 R888 on my 12" rear... I want to go 335 but scared it wont fit back there.
What offsets are you running with the R888/315 ?
You have a regular turbo not a gt2?
It is lowered?
With your help I my be able to narrow it down to what offsets I am going to order.
Old 06-05-2012, 12:19 PM
GT2rainge's Avatar
GT2rainge is just really niceGT2rainge is just really niceGT2rainge is just really niceGT2rainge is just really nice
It is lowered?
Standard gt2 offset is et45 with 12" and 315 from the factory, so that will work no problem. That is what I have always run with either mpsc or r888
Cheers
Old 06-05-2012, 12:31 PM
TurboTodd's Avatar
Cheers
Thanks for the info but that is for GT2 with rolled fenders
I think LiNKs has a regular turbo. If he is running gt2 offsets and R888s/315 successfully I'm in
Old 06-05-2012, 12:44 PM
n360rb's Avatar
n360rb is a jewel in the roughn360rb is a jewel in the roughn360rb is a jewel in the roughn360rb is a jewel in the rough
Great info thanks!
Yes...18's and offsets are 40 front and 45 back.
Lowered about an Inch with PSS10's
Plug in 2004 GT2 on Tire Rack's wheel selector and go to OZ wheels and the specs are there.
Old 06-05-2012, 01:02 PM
TurboTodd's Avatar
Thanks for the info, we are getting close. We know from your set up the GT2 spec wheels will fit a lowered turbo with Michelin 315s.
I would like to make sure the same set up will work with 315 R888
Old 06-05-2012, 09:24 PM
LiNks's Avatar
LiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond reputeLiNks has a reputation beyond repute
It is lowered?
I am lowered and my offset in the rear is +35 see below for some pics to give you an idea of the fitment and how much the car is dropped. I have had a few sets of wheels, played with spacers, and this is the perfect balance between super aggressive offsets and fully functional car to race on a track. I ran +28 before this on a 19"x12" wheel and a Mich PS2 315.... +35 and up on the rear 12" you will be happy and have no problems with a proper alignment and corner balance and any tire you choose in a 315
Old 06-06-2012, 02:07 PM
TurboTodd's Avatar
Thanks for all the input
I have ordered the wheels from Damon in the GT2 offsets.
Once installed I will report back as to fitment.
Old 06-11-2012, 02:43 PM
TurboTodd's Avatar
THEY FIT !!!
Just installed the rears as the fronts are back ordered. They fit with no problems at all. The wheels are the GT2 size and the tires are 315/18/R88s.
I had plenty of room on the inside, even with larger intercoolers and hoses.
I was prepared to roll the fenders but did not have to. I took the car for a test ride down some very rough roads with no rubbing at all.
The paper work from OZ even says they will fit the turbo with no mods.
Old 06-11-2012, 03:15 PM
LiNks's Avatar
You can add a 10 mm spacer in the rear and they will still fit
Old 06-11-2012, 05:49 PM
GT2rainge's Avatar
Hi Barth, sorry to go a little off topic.
Your cars sounds really sorted and how my car will be one day.
Do you go to the nordschleife a lot? Just wondered what alignment settings you run.
Cheers in advance
The_Ruski_Driver
10-25-2015 08:40 PM
turbotuner20v
09-11-2015 12:02 PM
FIRST_PORSCHE
08-30-2015 11:00 AM
Quick Reply: Anyone running 315 R888s on 12 inch rim?
