Quick parking brake question
Old 06-18-2012 | 01:38 PM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
Is it normal that the parking brake on the 996TT needs a good pull to grip? I noticed that the other day when I parked in the driveway. I know I need some new rotors in the back but that shouldn't really make that much of a difference.
Just want to make sure the car doesn't go rolling when I park on an incline in the mountains. Granted I can put it in gear but probably not the best idea to put the load on the transmission.
Thx!!
Old 06-18-2012 | 02:24 PM
thomapa1's Avatar
thomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of lightthomapa1 is a glorious beacon of light
Mine needed the be pulled all the way to max, then I adjusted the parking brake and it is better. Should take no more than 4-5 clicks to engage.
Basically, remove rear wheels, disengage parking brake, use a screwdriver through an access hole in the rotor to change the adjustment 'wheel'.
Search for how to adjust - I think there is a Youtube video that covers it while doing a brake job.
Old 06-18-2012 | 02:57 PM
FI_FTW's Avatar
Thanks for the great info!!
Old 06-18-2012 | 07:13 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
when i installed my new hand brake i had it to lose and the cables became tangled , well almost i adjusted from the cabin very simple
Old 06-18-2012 | 10:12 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
You can also adjust the parking brake handle. In the back consol compartment, there is a rubber mat, remove it and there is a plastic panel underneath it. Remove the panel and there you'll see the ebrake cables and the adjustment cam. Very easy to do.
Old 06-18-2012 | 11:43 PM
FI_FTW's Avatar
Thank you for the tip! I may check that out first.
Old 06-21-2012 | 05:30 PM
thats what i did worked fine
04-28-2022 12:38 AM
COBB Tuning
01-29-2022 09:42 AM
gulf gt
08-27-2015 10:27 AM
The Oss
08-24-2015 08:19 PM
Quick Reply: Quick parking brake question
