What throwout bearing for 964rs flywheel??
Does anyone know the part number or exact car it comes from for the throwout bearing that you should use with a 964rs lightweight flywheel ??
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
https://www.6speedonline.com/forums/...ost-one-3.html
RS LWFW conversion parts list
Clutch guide tube: 950 116 813 30
Guide tube screws: 900 270 055 02 (2 ea)
Starter ring gear: 964 114 143 31
Throw out bearing: 944 116 080 01
Flywheel bolts: 928 102 151 01 (9 ea)
Flywheel: 964 102 239 31
Pilot Bearing: 931 102 111 00
Pressure plate bolts: 999 510 015 02 (9 ea)
Note:
The following is added for the addition of the lightweight RS pulley. Porsche released a TSB on the 997 GT3 related to fix an issue with this stock weight pulley coming off when the lightweight flywheel is installed. So far I have not personally heard of this happening on the 996TT, but I personally would at least re torque and loctite the pulley bolts for good measure.
996 102 017 95 Crank pulley
999 025 174 02 Washer
996 102 550 80 Bolt
jaehoppa
10-22-2015 09:17 PM
alpha motoring
10-02-2015 12:04 PM
