Short metallic sound on startup?
I bet it is. ;-).
i sure don't think the sound i've heard ( or you've described ) is my starter, as folks are suggesting this noise might be ( although i suppose it could be(?). i've never been able to replicate the sound again ( not that i would really want to ) since never starting it again at that kind of angle which was what precipitated the horrible sound. i really do believe the noise i heard was metal to metal contact of parts that are normally lubricated that were momentarily not, and starting the car pumped oil back into where it belongs. who knows. still a mystery to me. i also HOPE it was my starter.
CO as in colorado?! LOL i think we may be confusing angles with altitudes.
Lots of people in mountains and hilly terrain makes for lots of opportunities to park at an angle . We may find a few in Beverly Hills too but those guys probably don't spend time on car forums; they just bring it to the dealer
true, my bad. i've been in the LA hills, seems like forever, but haven't been down in the "flats" more than a handful of times
Is this what a bad starter sounds like? Found this on youtube for "996+bad starter"
If it is, that was not the sound I was hearing. Mine was more a metallic sound and I believe the revs were a little lower while it was making the noise. Not so much a screeching sound like in this vid. I'm surprised I can't find more info on it. Not really anything through google either.
http://www.youtube.com/watch?v=WMs3ieE81oQ
Oil starvation diagnostic is ridiculous. Unless you parked it vertically - nose towards the ground!
Mine also happens very rarely. So you not hearing it again means nothing. Wait. If it happens again it will happen on level ground also. Then you know for sure.
Mine is much more metallic. This sounds like the belt.
I'll have to pay close attention at every startup and will report back once I know the definite cause.
I think what you may be hearing is the timing chain tensioner which sometimes leaks down over time if the car sits for an extended period. It takes a second or so to pressurize and the noise you hear is the rattle of the timing chain which has some slack to it. That is why you dont hear it on subsequent starts. I don't believe parking on an incline has anything to do with it. Hope that helps...
Yes, only very briefly during start up.
