Looking to replace my brake pads, Any suggestions for a aggressive street pad?
Old 06-26-2012 | 11:33 AM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
Low dust would be nice to.
Old 06-26-2012 | 12:23 PM
daedalus's Avatar
daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !daedalus Is a GOD !
cool carbon! Do a search - there is a lot of good feedback on them and they aren't as much as pagid's either.
Old 06-26-2012 | 01:28 PM
flavorPacket's Avatar
flavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond reputeflavorPacket has a reputation beyond repute
Ditto on the cool carbons. Dust performance isn't great, but they are relatively quiet and can handle a range of activities (heavy traffic, canyons, slower tracks)
Old 06-26-2012 | 02:17 PM
MBailey's Avatar
This is what I use in DD...
http://www.pagid-brake-pads.co.uk/pr...rbon-based.php
Old 06-26-2012 | 03:06 PM
pwdrhound's Avatar
I have the following pads on my Rturbo with 6 pot front calipers and 4 pot rears using slotted floating 350mm rotors front and rear.
Pagid yellow 19s: Dusted like crazy, noisy as heck, sensitive to proper bed in, mediocre performance on the street, decent on the track but get mushy after they are worn down past 50%
Cool carbons: Average dust, fairly quiet, mediocre performance on the street, terrible performance on the track (after a few 30 minute sessions the brake pads material basically crumbled apart and started chunking badly at the edges. I would not recommend these for the track for anything but a novice driver. If you are a driver in any of the upper groups like orange or black these will not work.
Endless MX72: Extremely low dust, very quiet, very good performance on the street and good on the track for 25 min sessions. This is a fantastic all around pad but quite pricey. If I recall, they were around $750 for the set but that was for the 6 pots.. For a street car that does occasional DE this is my favorite pad. Endless makes some very good pads from entry level stuff up to $2K+ enduro pads.
Performance friction 08 front and 06 rear: Average dust (less than OEM), fairly quiet, fantastic performance on both the street and track. This is my favorite track pad by far but what surprised my is how good they work on the street with excellent cold bite. They are the easiest pad to bed on that I have tried so far. I have the edges beveled and they are very quiet with just a hint of light squeal with light brake application. Also, they are reasonably priced at around $650 for the set.
Also, I didn't use the silly stick on vibration spider dampers with any of the above pads since they will melt right away at the track.....
Old 06-26-2012 | 04:12 PM
f1crazydriver's Avatar
f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !f1crazydriver Is a GOD !
1) What cooling ducks are you using for the brake pads?
2) My personal experience on the coolcarbons. I ran them twice, I believe i was one of their very first users to have them on. They are great for the street and track driving at 7/10s. You cannot dive in at the 3 marker, going 140mph at laguna seca, like I can with the PFC01's BUT for the avg guy they are amazing.
I did 4 flying laps with them 10/10s, with stock cooling ducs and on hoosiers r6's. i was going to fast for the run group that my friend was in ( I was driving his car for that session) they called me in, and the rotors caught on fire.
If you are not posting best lap times these brakes hold very well. If you want aggressive street driving these are perfect as they are quiet, low dust compare to other performance pads.
Old 06-26-2012 | 04:41 PM
pwdrhound's Avatar
I run the large 996GT3 Cup cooling ducts in the front and GT2 cooling ducts in the rear. I am however running at a +5000' elevation track which is pretty hard on the brakes. The cool carbons lasted 4 sessions before disintegrating in my case. The Endless pads had the least dust of any on the street, virtually none and held up great at the track.
Old 06-26-2012 | 04:46 PM
JSBear's Avatar
JSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond reputeJSBear has a reputation beyond repute
Do you think the Endless pads are worth more than double the
cost of the Cool Carbons for STREET use ?
Old 06-26-2012 | 06:08 PM
daedalus's Avatar
Essentially 150/front and 150/rear - 300 for all 4 corners:
http://www.pelicanparts.com/catalog/...pg6.htm#item23
Old 06-26-2012 | 10:57 PM
16v2911TT's Avatar
16v2911TT has a spectacular aura about16v2911TT has a spectacular aura about
Check out Hawk pads.
Old 06-26-2012 | 11:16 PM
i ended up getting Hawk HPS, I'll post my thought about these once I instal them .
Old 06-26-2012 | 11:29 PM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
Ive got a set of cool carbons that have been only used for 100 miles. PM me if interested
Old 07-03-2012 | 04:03 PM
I installed a set of Hawk HP2's on all four corners, So far so good! Granted they feel great and no complaints there isn't much to say after that.
Old 07-14-2012 | 11:52 PM
TimAZ's Avatar
TimAZ has a spectacular aura aboutTimAZ has a spectacular aura aboutTimAZ has a spectacular aura about
I agree here on the cool carbons...they suck for the track. I smoked them at Endie Motorsports park in Wilcox, AZ. They now sound like a truck on the street. I have sanded them down and can't quiet them down. I don't know if sanding the rotors a little bit for the new pads will help (textar for the street) or not. They are squealing now too. I like the PFC 01 the best. I can nail them and they come back for more. (track only)
Tim
Old 07-15-2012 | 12:58 AM
pwdrhound's Avatar
My PFC 06/08 combo is whisper quiet on slotted rotors with 6 pot fronts. I lightly beveled the edges on the fronts. The rears already came beveled from the factory. Fairly low dust too. Superb pads....
