Can Injectors Be Too Big?
Old 06-26-2012 | 09:41 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
As the title says really
Is there any negatives to running seriously big injectors?
Can they ever be to big?
I'm thinking about giving myself room to grow cuz I know you lot are a bad influence on me
Old 06-26-2012 | 09:54 PM
16v2911TT's Avatar
16v2911TT has a spectacular aura about16v2911TT has a spectacular aura about
Crappy idle at times...you shouldn't have any issues though if they're tuned correctly.
Old 06-27-2012 | 05:28 AM
Tim941NYC's Avatar
Yes they can be.. 996 ecu? If so then biggest for gas would be 1100cc to idle proper.
Old 06-27-2012 | 06:02 AM
pumalex's Avatar
pumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond reputepumalex has a reputation beyond repute
yes and an injector that isn't use to it's fullest potential (around 80% duty cycle) will have poor fuel atomisation which hurts fuel economy and performance.
Old 06-27-2012 | 08:28 AM
waymegelli's Avatar
waymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the roughwaymegelli is a jewel in the rough
I've got 87# injectors and Proto Todd is having trouble getting the tune just right. He hasn't come right out and said so, but I'm pretty sure he thinks they're too big.
Old 06-27-2012 | 09:40 PM
Tim941NYC's Avatar
Sounds odd as other cars are running that injector. Sure nothing else is at play here? Whats you rail psi?
Old 06-27-2012 | 10:56 PM
johnspeed's Avatar
Wouldnt adding another fuel pump add to that equation also??
Old 06-27-2012 | 11:06 PM
Turbo Fanatic's Avatar
Why would you want too much fuel? You want the right size for 80% duty cycle at your highest boost and small enough to idle properly.
Old 06-28-2012 | 04:35 AM
pumalex's Avatar
NO, unless the fuel pressure regulator isn't big enough, adding a fuel pump shouldn't raise the pressure as the regulator controls the pressure. It will only prevent the lost of pressure in case one isn't enough for the demand of the engine.
Old 06-28-2012 | 07:49 AM
ant_8u's Avatar
So what size injectors should I be looking at guys?
If I get injectors for a k24/18 will I need larger ones if I got to alpha 30s at a later date?
Or can I get a set of injectors that are suitable for both?
Old 06-28-2012 | 08:27 AM
there can be a lot of debate here but with 30rs you will need more fuel0 thus a bigger fuel system- injectors alone will not make it past 1.2 bar....
Ive seen clients run past 1.5 bar on 60s with a second series pump... but you can put in 80s as well.. both on 3.8 bar...
different tuners different approaches...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
albert@velosdesignwerks
American Muscle Vendor Classifieds
09-09-2015 04:21 PM
Other British Cars
09-09-2015 04:18 PM
09-09-2015 04:17 PM
Emre@Esmotor
09-09-2015 08:48 AM
Quick Reply: Can Injectors Be Too Big?
